write_eeprom() hangs program when WDT is enabled
PostPosted: Fri Nov 27, 2009 11:41 pm     Reply with quote
Hi All,
I am using PCML V4.095 with a PIC16F690.
Program I am working on is in final stages - passed all tests and debugging and I am in the process of enabling the watchdog for production - so the code before enabling the WDT works fine under all conditions.
I have a hard coded sleep() at the end of the main infinite loop as the chip spends most of its time asleep. I want the WDT to be on while the chip is awake and not when it is asleep - so from manuals and datasheets, easiest way seems to be to use software with setup_wdt().
All good so far - except the whole thing hangs when it hits a write_eeprom() function.
I have debugged this for hours and have managed to narrow it down to this function in a couple of spots - both in the main loop and inside an ISR. Put a setup_wdt(WDT_OFF) before the write_eeprom() and a setup_wdt(WDT_ON) after, and the program behaves.
So I guess, in a way I have fixed it - but my question to those with more experience with the CCS compiler is why??
Is this a bug, or am I configuring something wrong:
#fuses INTRC_IO, NOWDT, NOPROTECT
when I enter main() is set wdt up with:
setup_wdt(WDT_2304MS);
and at the top of the infinite loop:
setup_wdt(WDT_ON);
restart_wdt();
Some clarity from a greater mind than mine would be greatly appreciated.
Cheers,
Nigel
PostPosted: Sat Nov 28, 2009 2:00 am     Reply with quote
1. How do you know that it hangs on that line ? What method are you
using to determine that ?
2. Are you using a hardware debugger (ICD-U40 or ICD2, etc.) ?
If so, are you using the special 16F690-ICD header board ?
Are you single-stepping through the code or using breakpoints ?
3. Ideally, you would post a stripped-down (but compilable) program
that shows the problem, but with the smallest possible amount of code.
PostPosted: Sat Nov 28, 2009 2:49 pm     Reply with quote
Thanks for getting back PCM Programmer,
I am using printf's each step through the code. Not using a hardware debugger.
Sunday here in Oz and She Who Must Be Obeyed has banned me from working.
After sleeping on it, I am sure I must be doing something wrong - it doesn't make sense otherwise - will write some test routines tomorrow to see if I can reproduce the problem with a small chunk of code.
Will get back to you with the results.
Thanks,
Nigel
big_nige
PostPosted: Mon Nov 30, 2009 3:41 am     Reply with quote
Hi PCM Programmer,
Here is the smallest compilable chunk of code that produces the error. Realise that I could OR the setup_wdt commands, but that is not how they will be used in my program as the WDT is turned on and off in the main routine.
#include <16F690.h>
#fuses INTRC_IO,NOWDT,NOPROTECT
#use delay(clock=4000000, RESTART_WDT)
#use rs232(uart1, baud=57600, ERRORS, RESTART_WDT)
#use i2c(i2c1, master, FAST=400000)
printf("in main\r\n");
setup_wdt(WDT_ON);
while (TRUE) {
printf("start main loop\r\n");
output_high(PIN_C1);
delay_ms(1500);
output_low(PIN_C1);
delay_ms(1500);
printf("end of flash\r\n");
restart_wdt();
write_eeprom(0x00, 0xAF);
printf("%x written to eeprom\r\n", read_eeprom(0x00));
If you comment out the WDT setup "AF written to eeprom" gets printed out. If you enable them (as shown), it prints:
in main
start main loop
end of flash
and then starts to repeat, without getting to the other side of the write_eeprom.
Sorry about the 'hangs' in the subject text, it is not actually hanging the program, it is just resetting without executing the write_eeprom.
I am using the Microchip low pin count protoboard - hence the outputs to C1. They are mainly to test that the config for delay_ms is working.
#include <16F690.h>
setup_wdt(WDT_ON);
while (TRUE) {
delay_ms(1500);
output_low(PIN_C1);
delay_ms(1500);
restart_wdt();
PostPosted: Mon Nov 30, 2009 2:30 pm     Reply with quote
.................... setup_wdt(WDT_ON);
002F:  MOVLW  01
0030:  BSF    03.5
0031:  MOVWF  17    // Set WDTCON = 0x01
0032:  BTFSS  01.3  // Is PSA assigned to WDT ?
0033:  GOTO   037
0034:  BCF    01.0  // If so, set  pre-scaler to 1:1
0035:  BCF    01.1
0036:  BCF    01.2
The problem is caused by using WDT_ON alone, as the parameter.
It sets both pre-scalers to the minimum value, which results in a
WDT timeout period of about 1 ms. The write_eeprom() operation
takes 4 or 5 ms. That's why it's doing a WDT reset. When you
use WDT_ON alone, it over-writes your previous setting of 2304 ms.
You should enable the WDT by doing this:
and turn it off by doing this:
setup_wdt(WDT_OFF);
big_nige
PostPosted: Tue Dec 01, 2009 12:21 am     Reply with quote
aaahh - It all becomes clear Very Happy
Thanks for the advice - much appreciated.
Cheers,
Nigel
