interrupt-on-change problem with 12F609
nicksen
PostPosted: Mon Nov 23, 2009 8:46 am     Reply with quote
#include <12F609.h>
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES IOSC4                    //INTOSC speed 4 MHz
#FUSES NOPUT                    //No Power Up Timer
#define HALL_S0   PIN_A0
#define HALL_S1   PIN_A1
#define DIG_OUT   PIN_A2
#define GREEN_LED   PIN_A4
#define RED_LED   PIN_A5
#byte GPIO     =  0x05
#byte TRISIO   =  0x85
#INT_RA
void RA_isr(){
   int8 temp;
   temp = GPIO & 0x03;
   output_low(GREEN_LED);
void main(){
   int8 temp;
   TRISIO = 0x0B;
   output_low(DIG_OUT);
   output_high(RED_LED);      //LEDs are active LOW
   output_high(GREEN_LED);
   temp = GPIO;
   clear_interrupt(INT_RA);
   enable_interrupts(INT_RA0);//enable interrupts from both hall sensors
   enable_interrupts(INT_RA1);
   for( ; ; ){
Compiler version is 4.050. Interrupts-on-change don't fire. What I am missing? Any help will be greatly appreciated!
Thank You
PostPosted: Mon Nov 23, 2009 9:10 am     Reply with quote
You _either_ have to use the separate RA0/1 interrupt handler routines, or just enable INT_RA.
Using INT_RA0 or RA1, tells the compiler to add code to the global handler, to decode which pin has changed, and route to the corresponding handler. You are telling the compiler to do this, then not putting in these corresponding handlers....
nicksen
PostPosted: Tue Nov 24, 2009 4:11 pm     Reply with quote
I wish I could get PCM programmer's opinion.
meereck
PostPosted: Tue Nov 24, 2009 4:31 pm     Reply with quote
If you navigate to PICC/Devices directory, and look up the device header file, you will see there are several definitions:
#define INT_RA.....etc.
#define INT_RA0
#define INT_RA1
#define INT_RA2
#define INT_RA3
#define INT_RA4
#define INT_RA5
So if you do this
enable_interrupts(INT_RA0); //enable interrupts from both hall sensors
You also have to place proper interrupt handlers - i.e.
#INT_RA0
void ra0_isr()
//mycode
#INT_RA1
void ra1_isr()
//mycode
PostPosted: Tue Nov 24, 2009 4:44 pm     Reply with quote
There are no individual handlers. There is only the #INT_RA handler:
http://www.ccsinfo.com/forum/viewtopic.php?t=39835&start=3
PostPosted: Tue Nov 24, 2009 4:46 pm     Reply with quote
1. What is the Vdd voltage of your PIC ?
2. What are the voltage levels of the signals on pins RA0 and RA1 ?
Look at them with an oscilloscope.
meereck
PostPosted: Tue Nov 24, 2009 5:06 pm     Reply with quote
oops, my bad.
nicksen
PostPosted: Wed Nov 25, 2009 12:03 pm     Reply with quote
Vdd is +5V. RA0 and RA1 get clean 0V and +5V signals. Verified with o'scope.
PostPosted: Wed Nov 25, 2009 1:34 pm     Reply with quote
I compiled your program with versions 4.050 and 4.101 and compared
the .LST files with ExamDiff.
There are some problems in your version, as explained below.
.................... void main(){
0044:  CLRF   04
0045:  MOVLW  1F
0046:  ANDWF  03,F
0047:  MOVLW  62
0048:  BSF    03.5
0049:  MOVWF  10  // Set OSCTUNE = 0x62  (***Bug )
004A:  BCF    03.5
004B:  CLRF   1A
004C:  CLRF   1C
This code above is the start-up code. It writes to the OSCTUNE register
as if it's the OSCCON register (which doesn't exist in this PIC). That's
wrong. There's no reason to write to OSCTUNE. You should fix this in
your code by doing this:
#byte OSCTUNE = 0x90
OSCTUNE = 0;    // Fix bug in start-up code with vs. 4.050
That bug should be fixed, but I don't think it will affect your problem.
(This bug is not present in vs. 4.101).
There is another problem, and it's that the ANSEL register is left in it's
power-on reset state, which is "All analog". This affects pins RA0 and
RA1. CCS normally sets ANSEL to "all digital" in the start-up code. But
they don't do it in your version. In fact, they don't do it in vs. 4.101
either. You can fix it with this:
#byte ANSEL = 0x9F
ANSEL = 0;  // Make all Analog pins be digital i/o pins
I'll report this ANSEL setup problem to CCS.
