How do I convert float to Int or long?
cchappyboy
PostPosted: Tue Nov 24, 2009 11:51 am     Reply with quote
Is there any way to convert float to int or long in ccsc?
Any concern to be appreciate in advance.
meereck
PostPosted: Tue Nov 24, 2009 4:33 pm     Reply with quote
It is a standard C language, so:
int myval;
float test;
test=20.5;
myval=(int)test;
Piccolo
PostPosted: Tue Nov 24, 2009 5:33 pm     Reply with quote
Note: when you cast from a float to an integer your integer will "drop off" any of the original float value that was to the right of the decimal point. This means 20.5 will become 20 as an integer. Also, 20.9 will become 20, so make sure if you are converting from a float to an integer that you really don't need the decimal portion...
Ken Johnson
PostPosted: Wed Nov 25, 2009 7:54 am     Reply with quote
Depending on your needs, you may want to round up when doing this, e.g.
myval = (int) (test + 0.5);
But, consider the impact when test is negative!
Ken
