dnatechnical
need help for motor pwm |
Posted: Thu Nov 26, 2009 8:26 am |
Anybody can explain following command?
Want to use dspic30f3010.
setup_motor_pwm(pwm,options, timebase);
setup_motor_pwm_duty(pwm,unit,time)
set_motor_pwm_event(pwm,time)
setup_motor_unit(pwm,unit,options, active_deadtime, inactive_deadtime) |
What is time base ? Is it frequency or on period?
What is unit?
What is mean set_motor_pwm_event(pwm,time)?
thank you. |
