PICoHolic
[Resolved] Strange sw I2C behavior |
Posted: Sun Nov 22, 2009 5:03 am |
I was trying to implement an EEPROM copier. (24C16B, page by page)
The micro used is 12F675 with separate software I2C buses. Compiler 4.099
Here's the code:
#include <12F675.h>
#FUSES BANDGAP_HIGH
#use I2C(master, SLOW=100000, sda=PIN_A2, scl=PIN_A1, STREAM = SRC)
#use I2C(master, SLOW=100000, sda=PIN_A5, scl=PIN_A4, STREAM = DST)
#byte PORTA = 0x05
#byte IOC = 0x96
#bit LED = PORTA.0
#bit PBT = PORTA.0
int1 temp_flag;
int8 EEAddress,i,j,p, dummy8;
int1 SourceEEFound(int8 Address)
i2c_start(SRC);
temp_flag = i2c_write(SRC, Address);
i2c_stop(SRC);
return (!temp_flag);
int1 DestinationEEFound(int8 Address)
i2c_start(DST);
temp_flag = i2c_write(DST, Address);
i2c_stop(DST);
#int_RA
void RA_isr(void)
delay_ms(20);
while(!PBT);
delay_ms(20);
set_tris_a(0xFE);
if (SourceEEFound(0xA0)) //Source EEPROM found?
if (DestinationEEFound(0xA0)) //Destination EEPROM found?
for (i=0; i<8; i++) //8 blocks of EE
PORTA ^= 0x01; // toggle LED
EEAddress = 0xA0 | (i<<1); //Set source & destination EE address
i2c_start(SRC);
i2c_write(SRC, EEAddress);
i2c_write(SRC, 0x00); //point to address 0
i2c_start(SRC); //restart
i2c_write(SRC, EEAddress+1); //prepare reading
for (j=0; j<16; j++) //write one page at a time
i2c_start(DST);
i2c_write(DST, EEAddress);
i2c_write(DST, (j<<4));//point to start of page
for (p=0; p<16; p++) //write 16 bytes (1 page)
dummy8 = i2c_read(SRC);
i2c_write(DST, dummy8);
i2c_stop(DST); //stop on destination
delay_ms(10); //page write cycle
i2c_stop(SRC); //stop on source
else //Source not found
//Adjust destination EEPROM
set_tris_a(0xFF); //set port to input
swap(PORTA); //remove mismatch
//setup_adc(ADC_CLOCK_DIV_2);
//setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
//setup_timer_1(T1_DISABLED);
setup_comparator(NC_NC);
setup_vref(FALSE);
set_tris_a(0xFF);
port_a_pullups(TRUE);
IOC = 0x01;
enable_interrupts(INT_RA);
sleep();
delay_cycles(1);
The problem is inside the p loop:
the statement: dummy8 = i2c_read(SRC); has no effect (the I2C bus remains low) unless I remove the following lines from the j loop:
i2c_start(DST);
It seems that the compiler is mixing between the functions of the two sw i2c buses. It's reading from destination and writing to destination
Any idea?
Posted: Sun Nov 22, 2009 10:08 am |
The CCS manual doesn't give that as a valid syntax. It says that if
a stream is specified for this function, then the ACK (or NACK) must
also be specified. If you want to tell it to use a stream, you must
use two parameters. A single parameter is interpreted as ACK/NACK.
Here's the section from the manual:
Quote: |
I2C_read( )
Syntax: data = i2c_read();
data = i2c_read(ack);
data = i2c_read(stream, ack);
Parameters: ack -Optional, defaults to 1.
0 indicates do not ack.
1 indicates to ack.
stream - specify the stream defined in #USE I2C
PICoHolic
Posted: Sun Nov 22, 2009 10:41 am |
Thanks PCM programmer.
It seems working now.
I had another solution: reading then writing (page by page), the 'i' loop becomes:
dummy8 = j; //prepare start of page
//read page
i2c_start(SRC);
i2c_write(SRC, swap(dummy8)); //point to address (+=16)
DataBuff[p] = i2c_read(SRC);
//Write page
i2c_start(DST);
i2c_write(DST, dummy8);//point to start of page
i2c_write(DST, DataBuff[p]);
delay_ms(6); //page write cycle 6+4=10ms
It works even if [DataBuff[p] = i2c_read(SRC);]
Without adding the ACK!
Thanks anyway  |
Posted: Sun Nov 22, 2009 10:46 am |
That may be, but it's pure luck due to quirks in the way the compiler
handles functions which don't have a stream specified, when the library
is specified with a stream.
It's a violation of the syntax, and regarding it as a "solution" will burn
you either in this code or in future programs. |
PICoHolic
Posted: Sun Nov 22, 2009 11:08 am |
You're 100% right  |
