Olea Guest
PCD: Option invalid No PLL option |
Posted: Mon Nov 16, 2009 11:45 am |
This is the settings for PIC24.
#include <24FJ256GB110.h>
#device ADC=10
#device PASS_STRINGS=IN_RAM
#FUSES NOJTAG //JTAG disabled
#FUSES ICSP1 //ICD uses PGC1/PGD1 pins
#FUSES NOWINDIS //Watch Dog Timer in Window mode
#FUSES WPRES128 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16 //Watch Dog Timer PostScalar 1:32768
#FUSES NOCKSFSM //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES NOOSCIO //OSC2 is clock output
#FUSES NOIOL1WAY //Allows multiple reconfigurations of peripheral pins
#FUSES WPEND_LOW
#FUSES NOWPCFG
#FUSES NOWPDIS
#FUSES WPFP0
#FUSES PR_PLL //Enable PLL for primary oscillator?
#FUSES PLL2 //Divide By 2
#FUSES RESERVED //Used to set the reserved FUSE bits
#FUSES DISUVREG
#use delay(clock=24M, crystal=8M)
And this is the error:
Quote: |
Executing: "C:\PCD4099\Ccsc.exe" +FD "main.c" +DF +LN +T +A +M +Z +Y=9 +EA
*** Error 99 "C:\test\main.h" Line 28(5,34): Option invalid No PLL option |
What I'm trying to do is to change the HW external OSC.
The external osc was 25 MHz but because of testing, I have to switch it to
8MHz. So we made HW changes but when I compile the program I get
error, written above.
O. |
FvM
Posted: Mon Nov 16, 2009 3:17 pm |
You may have revealed the cause of problem by playing around with the settings...
Basically the below line is wrong:
Quote: | #use delay(clock=24M, crystal=8M) |
24M isn't a valid 24FJxxGB core clock, it has to be 32M. Curiously, PCD, that is ignoring all kind of defective settings
otherwise, is very critical in this point. It's also extracting some #fuses values from the #use delay entry, but you
better specify them separately, because some are extracted incorrectly. Omitting #fuse PLL2, that can be extracted
from the delay entry gives a PLL12 value... |
