HareRabbit Guest
| I need help for 12F675 code |
Posted: Fri Nov 13, 2009 10:51 pm |
I am starter for PIC programing. I use CCS-C and MPLAB 8.40. Also I use ICD 2 for programmer and debugger. My program has two external inputs, and two outputs. When (0,0) is input signal, the chip has to be in sleep mode, and when other signal is coming in, the predefined sequence is out as a output signal. I use the 20 MHz external oscillator as a clock input for GP5.
Since I am really newbie to PIC, I just use CCS-C project wizard and basic functions in help file. The following code is not working at all... But I don't know the reason. When I tried to compile the c code by using CCS-C, there is no error and warning, but the code is just not working. Please help me and let me know the wrong part and the possible solution.
*The code is little long, but the functions are really simple... I don't know why it is not working at all. Plz teach me in anyway.
#include <12F675.h>
#device adc=8
#FUSES EC_IO //External clock
#FUSES NOMCLR //Master Clear pin used for I/O
#FUSES BANDGAP_HIGH
#define GP0 PIN_A0
#define GP1 PIN_A1
#define GP2 PIN_A2
#define GP3 PIN_A3
#define GP4 PIN_A4
#define GP5 PIN_A5
// global flag to send processor into sleep mode
short sleep_mode;
// external interrupt to control sleep_mode
#int_EXT
void EXT_isr() {
static short rest_signal=FALSE;
if(input(GP3)) // check weather signal is 01 or 00
rest_signal=TRUE;
if(!rest_signal) // if signal is 00(rest)
rest_signal=TRUE; // the 00 signal in
sleep_mode=TRUE; // activate sleep
ext_int_edge(L_TO_H); // change interrupt to wakeup
else // if signal is 01(right_turn)
rest_signal=FALSE; // reset the rest_mode
sleep_mode=FALSE; // reset sleep flag
ext_int_edge(H_TO_L); // reset interrupt to wait sleep
// sequence for forward motion
void sequence_forward (void)
output_high(GP4);
delay_ms(2000);
output_low(GP4); // 1
delay_ms(100); // preventing overheatting
output_high(GP4);
delay_ms(2000);
delay_ms(2000); // 0
output_high(GP0);
delay_ms(2000);
output_low(GP0); // -1
output_high(GP0);
delay_ms(2000);
output_high(GP0);
delay_ms(2000);
output_high(GP0);
delay_ms(2000);
output_high(GP4);
delay_ms(2000);
output_high(GP4);
delay_ms(2000);
// sequence for right turn
void sequence_right (void)
output_high(GP4);
delay_ms(2000);
output_high(GP4);
delay_ms(2000);
output_high(GP4);
delay_ms(2000);
output_high(GP4);
delay_ms(2000);
output_high(GP4);
delay_ms(2000);
output_high(GP4);
delay_ms(2000);
output_high(GP0);
delay_ms(2000);
output_high(GP0);
delay_ms(2000);
output_high(GP0);
delay_ms(2000);
output_high(GP0);
delay_ms(2000);
output_high(GP4);
delay_ms(2000);
output_high(GP4);
delay_ms(2000);
// sequence for left turn
void sequence_left (void)
output_high(GP4);
delay_ms(2000);
output_high(GP4);
delay_ms(2000);
output_high(GP0);
delay_ms(2000);
output_high(GP0);
delay_ms(2000);
output_high(GP0);
delay_ms(2000);
output_high(GP0);
delay_ms(2000);
output_high(GP0);
delay_ms(2000);
output_high(GP0);
delay_ms(2000);
output_high(GP0);
delay_ms(2000);
output_high(GP0);
delay_ms(2000);
output_high(GP4);
delay_ms(2000);
output_high(GP4);
delay_ms(2000);
// main program for sequence control and sleep management
setup_adc(ADC_OFF);
setup_timer_1(T1_DISABLED);
setup_comparator(NC_NC);
setup_vref(FALSE);
sleep_mode=FALSE; // initiate sleep flag
output_low(GP0);
output_low(GP4); // set initial output ground
ext_int_edge(H_to_L); // init interrupt triggering for 00 signal
enable_interrupts(int_EXT);
delay_ms(1000); // tunning delay
while(TRUE){
if(sleep_mode) // if sleep flag set
sleep(); // make processor sleep
if(input(GP2) && input(GP3)) // when 11 signal, forward motion
sequence_forward ();
else if(input(GP2) && !input(GP3)) // when 10 signal, left turnning
sequence_left ();
else if(!input(GP2) && input(GP3)) // when 01 signal, right turnning
sequence_right ();
delay_ms(10);
Posted: Sun Nov 15, 2009 1:21 am |
My advice is, for debugging purposes, get rid of the code in those huge
routines. Comment it out. Replace it with some simple code that just
turns on an LED for one second. This can be done in 3 lines of code.
Also, consider reducing your control inputs to just one pin, for this test.
Reduce the complexity until you can get something that works. Then
add the complexity back in, a little bit at a time. Test it at each step
to prove that it still works. |
bungee-
Posted: Sun Nov 15, 2009 3:59 am |
For start try to enable:
Power Up Timer prepares the PIC to start correctly. And as PCM programmer said, try first just to "blink" leds and then step up with complexity.
You are using sleep mode try first to determine if your PIC goes and comes out of sleep mode as it should.  |
Posted: Sun Nov 15, 2009 4:03 am |
One further 'obvious comment', is that the INT_EXT code tests GP3. INT_EXT on a 12F675, is on GP2.....
