WDT on 18f4550
oliv
WDT on 18f4550
PostPosted: Wed Nov 04, 2009 5:23 am     Reply with quote
I can't change the WDT time.
Fuses are set to WDT1024 but I haven't reset before 2mn.
Someone had already got this problem ?
PostPosted: Wed Nov 04, 2009 11:54 am     Reply with quote
Post a short, compilable test program that shows the problem. Example:
http://www.ccsinfo.com/forum/viewtopic.php?t=23411&start=13
Post your compiler version.
Also post if you are trying to test the Watchdog while running the
ICD debugger.
oliv
PostPosted: Fri Nov 06, 2009 5:15 am     Reply with quote
my compiler :
CCS V_4.99.2.12
and here is a code looking my principal code.
#include <18F4550.h>
    #fuses HSPLL,WDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
    #fuses WDT1024
void main (void)
   char commande;
   LED_OFF(LED1);
   LED_OFF(LED2);
   usb_init_cs();
   lcd_init();
   switch ( restart_cause() )
         case WDT_TIMEOUT:
            lcd_gotoxy(1,1);
            printf(lcd_putc,"WDT restart ...");
         default :
            lcd_gotoxy(1,1);
            printf(lcd_putc,"normal start ...");
   setup_wdt(WDT_ON);
   while (TRUE)
      usb_task();
      usb_debug_task();
      restart_wdt();
      lcd_gotoxy(1,2);
      printf(lcd_putc,"prog running -");
       if (usb_cdc_kbhit())
            commande=usb_cdc_getc();
            if (commande==0x09)       //test watch dog
               while (TRUE)               //
      lcd_gotoxy(1,2);
      printf(lcd_putc,"prog running /");
PostPosted: Fri Nov 06, 2009 1:43 pm     Reply with quote
That's not a compilable test program.
But, you need to move the test for restart cause to the top of main().
Put it just after the variable declarations in main(), before any other
lines of code.
I don't think you need all that USB stuff to test the watchdog timer's
timeout period. Make a simple, complete, short test program.
oliv
PostPosted: Tue Nov 10, 2009 2:27 am     Reply with quote
This is the context my program need to run.
The lacking part of it is a Microchip example "ex_usb_serial".
And the restart cause is working good when WDT restart.
But WDT is already prescaling by 32000.
I can do a test prog, but I think my problem is in the configuration of the WDT.
Do you think that usb is the cause of my problem ?
PostPosted: Tue Nov 10, 2009 1:03 pm     Reply with quote
You didn't want to make a test program, so I made one.
I used the CCS WDT example file for the PIC18 series:
c:\program files\picc\examples\ex_wdt18.c
I kept the code in main() unchanged, but I substituted the 18F4550 and
I used your #fuses statements. You have the PLL5 fuse in your code
which means a 20 MHz crystal or external oscillator is being used.
I installed that crystal on my PicDem2-Plus board. With the HSPLL fuse,
this gives a 48 MHz oscillator frequency, so I put that frequency into
the #use delay statement.
I ran the program and I timed the Watchdog timeouts with a stopwatch.
They occur about every 4.6 seconds. The expected timeout period is
128 x 1024
----------- = 4.23 Seconds
  31 KHz
The internal 31 KHz oscillator has an accuracy of +/- 15%, so 4.6 seconds
is within the expected range for the WDT timeout period. So, it's working.
#fuses WDT1024
#use delay(clock=48000000)
This was tested with vs. 4.099 of the compiler.
