meereck
| 4.093 bug: int1 arrays comparison condition |
Posted: Mon Nov 09, 2009 11:27 am |
Hello everybody,
I have stumbled upon a terrible bug. I took my project and created the following shorter listening out of it.
The issue is that condition if(PinState[i]!=PinStatePrevious[i]) is always false regardless those variables.
In printf("pin%i: %i %i\n",i,PinState[i],PinStatePrevious[i]); you can see that both variables have the same value!
Use #define SHOW_BUG to show the issue and a workaround.
The application sends a string to the serial line when one of higher 4 bits of PORTB changes its state.
The bug sends the string all the time.
Hope it is clear for you.
Does anybody know whether this issue has been reported to CCS (and solved in later version of the compiler)?
I hope I am not stupid and this issue really is a compiler bug.
Cheers
#include <18F2420.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES PROTECT //Code protected from reads
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PUT //Power Up Timer
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#use delay(clock=20000000)
#use fast_io(B)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,errors)
#define TRIS_B 0b11110010
#define INPUT_COUNT 4
#ZERO_RAM
#define SHOW_BUG 1//change it to 0 to see that the other condition works well
int1 PinState[INPUT_COUNT];
int1 PinStatePrevious[INPUT_COUNT];
int8 val,i;
int1 bool1,bool2;
port_b_pullups(TRUE);
setup_adc(ADC_OFF|ADC_TAD_MUL_0);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_4);//52ms
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
set_tris_b(TRIS_B);
val=input_b();
val=val>>4;//B4-B7
printf("val: %X\n",val);
for(i=0;i<INPUT_COUNT;i++)
PinState[i]=(val&(1<<i));
bool1=PinState[i];
bool2=PinStatePrevious[i];
printf("pin%i: %i %i\n",i,bool1,bool2);
#if SHOW_BUG
if(PinState[i]!=PinStatePrevious[i])//doesnt work, is always false
#else
if(bool1!=bool2)//works
printf("pin%i changed\n",i);
PinStatePrevious[i]=PinState[i];
