is there any wrong in my lcd code for picdem 2plus with 18f
pyae54silver
PostPosted: Fri Nov 06, 2009 11:27 am     Reply with quote
#include <p18F452.h>
#include <delays.h>
#include "lcd.h" // Include file is located in the project directory
#define LCD_RS PORTDbits.RD4 // Register Select on LCD
#define LCD_EN PORTDbits.RD6 // Enable on LCD controller
#define LCD_WR PORTDbits.RD5 // Write on LCD controller
//--- Function for writing a command byte to the LCD in 4 bit mode --------
void lcd_write_cmd(signed char cmd)
unsigned char temp2;
LCD_RS = 0; // Select LCD for command mode
Delay10TCYx(4); // 40us delay for LCD to settle down
temp2 = cmd;
temp2 = temp2 >> 4; // Output upper 4 bits, by shifting out
//lower 4 bits
PORTD = temp2 & 0x0F; // Output to PORTD which is connected
//to LCD
Delay1KTCYx(10);
//lcd_strobe(); // E pulse to strobe in data
LCD_EN = 1; // E = 0
Delay1KTCYx(10); // 10ms delay for LCD_EN to settle
LCD_EN = 0; // E = 1
Delay1KTCYx(10);
temp2 = cmd; // Re-initialise temp2
PORTD = temp2 & 0x0F; // Mask out upper 4 bits
Delay1KTCYx(10);
//lcd_strobe();
Delay1KTCYx(10);
void lcd_write_data(char data)
char temp1;
LCD_RS = 1; // Select LCD for data mode
Delay10TCYx(4);
temp1 = data;
temp1 = temp1 >> 4;
PORTD = temp1 & 0x0F;
LCD_RS = 1;
Delay1KTCYx(10); //_-_ strobe data in
//lcd_strobe();
Delay1KTCYx(10);
temp1 = data;
LCD_RS = 1;
Delay1KTCYx(10);
/*//-- Function to generate the strobe signal for command and character------
void lcd_strobe(void) // Generate the E pulse
//---- Function to initialise LCD module ----------------------------------
void lcd_init(void)
TRISD = 0x00;
PORTD = 0x00; // PORTD is connected to LCD data pin
LCD_EN = 0;
LCD_WR = 0; // Select LCD for write mode
Delay10KTCYx(250); //
Delay10KTCYx(250);
lcd_write_cmd(0x33);
lcd_write_cmd(0x32);
lcd_write_cmd(0x28); // 001010xx – Function Set instruction
// DL=0 :4-bit interface,N=1 :2
//lines,F=0 :5x7 dots
lcd_write_cmd(0x0E); // 00001110 – Display On/Off Control
//instruction D=1 :Display on,
// C=1 :Cursor on,B=0 :Cursor Blink on
lcd_write_cmd(0x06); // 00000110 – Entry Mode Set
//instruction I/D=1 :Increment Cursorposition, S=0 : No display shift
lcd_write_cmd(0x01); // 00000001 Clear Display instruction
Delay1KTCYx(20); // 20 ms delay
lcd_init(); // Initialise LCD module
LCD_RS = 1; // Select LCD for character data mode
Delay1KTCYx(1); // 1 ms delay
lcd_write_cmd(0x80); // Move cursor to line 1 position 1
lcd_write_data(0x41); // write "A" to LCD
lcd_write_data(0x42); // write "B" to LCD
lcd_write_data(0x43); // write "C" to LCD
lcd_write_cmd(0xC0); // Move cursor to line 2 position 1
lcd_write_data(0x31); // write "1" to LCD
lcd_write_data(0x32); // write "2" to LCD
lcd_write_data(0x33); // write "3" to LCD
while(1); //stop here for now
pyae54silver
ANY ONE CAN HELP PLS
PostPosted: Fri Nov 06, 2009 11:31 am     Reply with quote
Though there is no error in program and i can download it to my mcu but it didn't show any thing on lcd.. is there anything wrong.. anyone can help me pls thz
PostPosted: Fri Nov 06, 2009 11:35 am     Reply with quote
The main thing wrong is that this is C18 code and you're on the CCS
forum. You need to be on the C18 forum:
http://www.microchip.com/forums/tt.aspx?forumid=3
