please help me the arduino code translate ccs c code.
cogitoist
PostPosted: Wed Nov 04, 2009 6:41 pm     Reply with quote
please help me the arduino code translate to ccs c code for 12f675.
The code is using Led Fire Effect.
Thanks for your helping.
-- Sad sinan
int ledPin1 = 10;
int ledPin2 = 9;
int ledPin3 = 11;
void setup()
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
void loop() {
analogWrite(ledPin1, random(x)+(255-x));
analogWrite(ledPin2, random(y)+(255-y));
analogWrite(ledPin3, random(z)+(255-z));
delay(random(100));
andyfraser
PostPosted: Wed Nov 04, 2009 6:53 pm     Reply with quote
If you spend 10 minutes reading the CCS manual you should have no problem converting this to CCS code.
Andy
www.sharpcontrols.net :: Free custom controls for .NET
FvM
PostPosted: Thu Nov 05, 2009 12:42 am     Reply with quote
I don't agree. The said proprietary function analog_write() provides a software-PWM, no similar CCS built-in function exists.
It wouldn't be of much general use in my opinion, because it restricts the system performance seriously and thus
doesn't meet the requirements of embedded computing. A similar functionality can be implemented with
CCS C, if the processor is free of critical real-time tasks. But it can't be found in the CCS manual or examples.
andyfraser
PostPosted: Thu Nov 05, 2009 11:37 am     Reply with quote
Point taken, I should have spent more than 10 seconds reading the OP's post. Apologies to sinan for my terse reply Crying or Very sad
cogitoist
hi there,
PostPosted: Thu Nov 05, 2009 12:05 pm     Reply with quote
I know not included ccs c compiler this command (analog_write()).
But I need this fire effect ccs c code.
How do they do it for the 12f675 ?
PostPosted: Thu Nov 05, 2009 12:30 pm     Reply with quote
This thread has software PWM code that should work on a 12F675:
http://www.ccsinfo.com/forum/viewtopic.php?t=37807
