How to resolve problems pointer to pointer like dj->fs-&a
jamilsalem
PostPosted: Fri Nov 06, 2009 8:07 am     Reply with quote
Dear Sir,
I am trying to convert the elm FATFS code for FAT16/32 to CCS.
http://elm-chan.org/fsw/ff/00index_e.html.
I got an error when compile statments like
dj->fs->n_rootdir
and
FATFS**
I received the following error codes:
Internal Error - Contact CCS
Access violation at address 03D131F8 in module 'PCH.dll'. Read of address 0B1499B4
Could you help me to solve this problem?
Thank you.
Sincerely,
Jamil Barbar
jamilsalem@gmail.com
SherpaDoug
PostPosted: Fri Nov 06, 2009 11:50 am     Reply with quote
You should contact customer support at CCS if you get "Internal Error - Contact CCS ." They don't always read this BBS.
PostPosted: Fri Nov 06, 2009 12:35 pm     Reply with quote
As a 'bodge' though, I'd remove the double indirection.
Declare a local pointer to the last type, and copy the first pointer into it, then use this. Advanced constructs like this, do give problems, I think because the compiler bases it's arithmetic on pointer size, on the variable used, and when accessing a pointer to a pointer, loses track of this value.
