A Math question??
rr2
A Math question??
PostPosted: Wed Nov 04, 2009 10:39 am     Reply with quote
I facing a "simple" but complicated problem to me.
I need to take some values from a linear graphic where:
5Vdc = 1.0000Mpa
1Vdc = 0.0000Mpa
0,6Vdc = -0.100Mpa
I have the "volts" but i can´t make the formula to get the midle values. Embarassed of Mpa
Mpa = units of a pressure sensor.
Thanks in advance
RR2.
Alberto
Re: A Math question??
PostPosted: Wed Nov 04, 2009 10:48 am     Reply with quote
rr2 wrote:
5Vdc = 1.0000Mpa
1Vdc = 0.0000Mpa
0,6Vdc = -0.100Mpa
Thanks in advance
RR2.
if it is a line the formula is y = x*m + offset, the offset is the value for x=0 so if x is Mpa the offset is 1Vdc, m is the slope, that is (5Vdc-1Vdc)/1Mpa = 4Vdc/Mpa
y = x*4Vdc/Mpa + 1Vdc, with x the value in Mpa and y the result in Vdc
if you have volts, you can do x = (y-1)/4, that is your formula
rr2
PostPosted: Thu Nov 05, 2009 4:15 am     Reply with quote
Thank´s very much.
It´s really simple Embarassed
Bye
