LCD driver string formating
Username0C
PostPosted: Sun Nov 01, 2009 8:37 am     Reply with quote
I'm having problems with lcd eaDogme string formatting.
The driver from the code library is working OK but I don't know how
to set some signs or how to use \f .
What I want to do is set the >> sign before some other text.
printf(lcd_putc,"\f >> %s",Value);
In eadogme this should be set like this:
printf(eaDogM_WriteString, Value);
but on this way I can't set any >> sign
so this should be done like:
#define EADMSYM_DARWR   0b11111100     // double >>
void eaDogM_double(void) {
   eaDogM_WriteCommand(EADMSYM_DARWR);
But how to call it inside WriteString function ?.
PostPosted: Sun Nov 01, 2009 2:58 pm     Reply with quote
You could use sprintf() to put formatted output into a character buffer
(an array). Then give the buffer to the EADogm write_string routine.
I don't think that's true.
At the top of his program, he says the function takes a single char
as the argument:
eaDogM_WriteString(char str); // writes a string to the display
But then within the program, he now says it takes a string pointer:
void eaDogM_WriteString(char *strPtr)
Your proposed code assumes that his first definition is correct.
But in fact, the write string function really expects a string buffer.
That's why I suggested using sprintf() to make string, and put it into
a buffer (you must declare the buffer before using sprintf), and then
give the buffer to the write string function.
