create sounds with pic
jennifer
PostPosted: Sun Nov 01, 2009 8:50 am     Reply with quote
hi ,
I want to create a music box with pic16f690.
I started to produce songs with the pwm pin and changing the frequency.
The song is playing well, but the sounds that the speaker produce are so monotonics... (300-550hz), sound like old days.
Can I do some dsp to create a more full, capacity sounds?
A low pass will help? or some software manipulations ?
Thanks.
jenn
can someone
PostPosted: Mon Nov 02, 2009 3:16 am     Reply with quote
Can someone please help me with this ?
What code manipulation should I do to create a more spacy sounds ?
PostPosted: Mon Nov 02, 2009 9:51 am     Reply with quote
Did you check the code library? One of the 'regulars' (Ttelmah?) posted a music generation project a while back....
Chuck
yerpa
PostPosted: Mon Nov 02, 2009 3:35 pm     Reply with quote
There is a sound synthesizer with source code (for the PIC 18F series) here:
http://www.reprolabs.com/fraktal_synth_1.htm
You might get some ideas from the various sound producing algorithms. The multiply instruction available on the 18F series gives a good advantage compared to the 16F series.
