CCS IDE Automation
maxrate
CCS IDE Automation
PostPosted: Thu Nov 05, 2009 6:25 pm     Reply with quote
Is there a way with a single keypress/click of a button that could: CLEAN / COMPILE / BUILD ALL / PROGRAM CHIP ?
thank you!
PostPosted: Thu Nov 05, 2009 8:50 pm     Reply with quote
Which IDE are you using? CCS or MPLAB?
In MPLAB under "Project / Build Options / Project / Custom Build" there is an option for a Post-Build Step. Place here a call to your programming tool. For example the PicKit2 has a separate command line interface tool you can call from here.
maxrate
PostPosted: Fri Nov 06, 2009 2:21 pm     Reply with quote
I'm using CCS development environment - no mplab
thank you
