Can a watch crystal be used with a 16F690 for an RTC ??
arunb
PostPosted: Fri Oct 30, 2009 3:39 am     Reply with quote
How can I connect a 32.768 Khz crystal to a 16F690 mcu.
I need to use this crystal as a RTC and generate an interrupt. The mcu would work on the internal oscillator at 8 Mhz.
Is this possible with 16F690 ??? I used to do this with a 16F628 and a 16F648A mcu, the PICs derived the RTC timing interrupt from the watch crystal but run on internal oscillator mode.
Please help...
thanks
a
FvM
PostPosted: Fri Oct 30, 2009 6:28 am     Reply with quote
Microchip has an application note about it. http://ww1.microchip.com/downloads/en/AppNotes/91097A.pdf
PostPosted: Fri Oct 30, 2009 6:32 am     Reply with quote
Yes, but you don't connect the watch crystal to the master oscillator pins.
Connect it to T1CKI and T1G pins.
Then setup Timer1, with T1_EXTERNAL | T1_CLK_OUT, which enables the oscillator between these pins. Obviously add the required capacitors, to get the frequency right.
Timer1 then counts using the external crystal, and you can run the CPU itself off any other clock you want. INTRC_IO, with a clock setting of 8MHz, gves you operation off the internal 8MHz RC clock.
FvM
PostPosted: Fri Oct 30, 2009 10:19 am     Reply with quote
They are the same with 16F690.
arunb
RE:
PostPosted: Sat Oct 31, 2009 3:15 am     Reply with quote
Thank you for the help..it was the most informative
a
