problem with receiver circuit
giustraman
PostPosted: Wed Oct 28, 2009 4:23 am     Reply with quote
I'm trying to measure temperature thanks a transmitter-receiver circuit. I have a problem with the receiver: External interrupt setting on rising edge do not function: for example I have introduced a spike to check its execution (output high / low on pin) but I do not view anything on a oscillator. Somebody could help me?? Best regards..
#include <16F648A.h>
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOMCLR                   //Master Clear pin used for I/O
#include "C:\Documents and Settings\Administrator\Desktop\ricevitore\16f648.h"
#include <lcd_16x2.c>
int1 id[16]={1,0,1,0,1,0,1,0,1,1,0,0,1,1,0,0}, vett[48], stato_bit, stato_id, parita;
int i, j, k, h, count, count_k, delay_bits, count_edge, temp, temp_old, temp_int, temp_dec, an2, an2_old, an2_int, an2_dec;
#int_EXT
void  EXT_isr(void)
   output_high(PIN_A4);
   output_low(PIN_A4);
   if(count_edge!=0)
      delay_bits=get_timer0();
   set_timer0(0);
   delay_us(500);
   stato_bit=input_state(pin_B0);
   if(((delay_bits<48)||(delay_bits>80))&&(count_edge!=0))
      count_edge=0;
      j=0;
   if(stato_bit)
      vett[j]=1;
      vett[j]=0;
   count_edge++;
   if(j==47)
         j=0;
      j++;
#int_TIMER0
void  TIMER0_isr(void)
   count_edge=0;
   j=0;
void controllo_id()
   for(k=0;k<16;k++)
      if((vett[k]==id[k]))
         count_k++;
   if(count_k==16)
      stato_id=true;
      stato_id=false;
void controllo_parita()
      parita=false;
      count=0;
      for(i=0;i<16;i++)
         if(vett[i]==1)
            count++;
      for(i=17;i<48;i++)
         if(vett[i]==1)
            count++;
      if(((count%2==1)&&(vett[16]==1))||((count%2==0)&&(vett[16]==0)))
         parita=true;
      vett[16]=0;
void visualizza_temp()
   for(h=0;h<16;h++)
      temp+=vett[h+16]*2^(16-h);
   if(temp!=temp_old)
      temp_int=temp/10;
      temp_dec=temp%10;
      printf(lcd_putc,"\fTemperatura in C\n%d.%d 'C",temp_int,temp_dec);
      temp_int=temp_old/10;
      temp_dec=temp_old%10;
      printf(lcd_putc,"\fTemperatura in C\n%d.%d 'C (*)",temp_int,temp_dec);
   temp_old=temp;
void visualizza_an2()
   for(h=0;h<16;h++)
      an2+=vett[h+32]*2^(32-h);
   if(an2!=an2_old)
      an2_int=an2/10;
      an2_dec=an2%10;
      //printf(lcd_putc,"\fIngresso an2\n%d.%d",an2_int,an2_dec);
      an2_int=an2_old/10;
      an2_dec=an2_old%10;
      //printf(lcd_putc,"\fIngresso an2\n%d.%d (*)",an2_int,an2_dec);
   an2_old=an2;
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_16); // va in overflow ogni 4ms
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   ext_int_edge(L_TO_H);
   enable_interrupts(INT_EXT);
   setup_oscillator(OSC_4MHZ);
   lcd_init();
      output_high(PIN_A2);
      output_low(PIN_A2);
      if(count_edge==48)
         disable_interrupts(INT_EXT);
         output_high(PIN_A3);
         output_low(PIN_A3);
         controllo_id();
         if(stato_id)
            controllo_parita();
      //comandi lcd
      if((stato_id==true)&&(parita==true))
         visualizza_temp();
         visualizza_an2();
      //abilitazione interrupt ext dopo aver visualizzato i dati sull'LCD
giustraman
PostPosted: Wed Oct 28, 2009 4:48 am     Reply with quote
do not verify the condition:
if(count_edge==48)
PostPosted: Wed Oct 28, 2009 11:19 am     Reply with quote
Is this a chip (integrated circuit) ? If so, post the manufacturer and part
number of the temperature chip.
