i2c problems
ncvnmarket
i2c problems
PostPosted: Sat Oct 24, 2009 7:49 pm     Reply with quote
Hi guys,
I'd like to send data from master (in one PIC 16f877a) and receive the data from slave (in another PIC 16f877a). I don't know why the code does not work right. I check the output from the master and clk and sda look fine, but when I connect two lines to slave then check the signal again, the clock is low (0) and the data is high (1). Here is my code:
Master:
#include <16F877A.h>
#device adc=8
#fuses NOWDT,RC, NOPUT, NOPROTECT, NODEBUG, BROWNOUT, LVP, NOCPD, NOWRT
#use I2C(master, sda=PIN_C4, scl=PIN_C3)
void sendData(BYTE data);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
    while (1){
      delay_ms (5);
      sendData(0b11111111);
void sendData(BYTE data){
   i2c_start();    // Start condition
   delay_cycles(5);
   i2c_write(0xa0);// Device address
   delay_cycles(5);
   i2c_write(data);// Low byte of command
   delay_cycles(5);
   i2c_stop();
Slave:
#device adc=8
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0xa0)
unsigned int dat;
#INT_SSP
void ssp_interupt ()
   //clear_interrupt(int_SSP);
   //while(!i2c_poll()) ;
   dat = i2c_read();
   i2c_write(0);
   set_tris_c(0xFF);
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_vref(FALSE);
   enable_interrupts(INT_SSP);      //enable I2C interrupts
   //dat=0;
   while(1){
     // while(!i2c_poll()) ;
     // dat = i2c_read();
      if (dat==0b11111111) {
         output_high(PIN_A0);
      } else {
         output_low(PIN_A0);
I want to compare the received data and sending data and ensure that it is same.
Thanks.
PostPosted: Sat Oct 24, 2009 9:15 pm     Reply with quote
Try the test given in this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=37876&start=1
Remember to include the pull-up resistors. If it doesn't work, then post
your PICs (master and slave) and your compiler version.
More information:
http://www.ccsinfo.com/forum/viewtopic.php?t=39242
ncvnmarket
PostPosted: Sun Oct 25, 2009 4:11 am     Reply with quote
I followed the code you gave me and modified it and It works...
Thanks so much
