How can I change the default pin_xx
sindyme
PostPosted: Sun Nov 29, 2009 9:13 pm     Reply with quote
The LCD example of the pin - define is (LCD.C)
// As defined in the following structure the pin connection is as follows:
// D0 enable
// D1 rs
// D2 rw
// D4 D4
// D5 D5
// D6 D6
// D7 D7
how can i change these default value ?
i try
#define enable PIN_d3
and
can't change ~
please tell me the syntax , thanks !
PostPosted: Sun Nov 29, 2009 9:26 pm     Reply with quote
Use the Flex lcd driver in the Code Library forum. The instructions for
the driver explain how to change the pins in the #define statements:
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
