[pic18f2550] Setting timer interrupts & USB HID
KT315
PostPosted: Tue Oct 27, 2009 5:46 am     Reply with quote
Hi!
I'm new to CCS and I cant sort out how to use timer interrupt.
I'm using pic18f2550 chip with 20MHz crystal resonator to create an usb hid device.
Now I want something to happen each second. So, the way to do this is using Timer0 Interrupt.
I've chosen divider 128 that should give about 152 timer events per second.
I'm using this code:
#include <18F2550.h>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock = 20000000)
#define SET_TICKS_PER_ACTION 152
unsigned int8 tmrTmr=0;
#int_timer0
void clock_isr()
    tmrTmr++;
    if (tmrTmr >= SET_TICKS_PER_ACTION)
      tmrTmr=0;
      // One second passed, do something
void main (void)
   setup_timer_0(RTCC_EXT_H_TO_L | RTCC_DIV_128 | RTCC_8_BIT);
   set_timer0(0);
   usb_init_cs();
   while (1)
      usb_task();
      if (usb_enumerated())
          // some hid events
But there's no action, that should be every second. Where am I mistaken?
Thanks!
Or maybe there's a good way to work with timer by polling method?
PostPosted: Tue Oct 27, 2009 6:27 am     Reply with quote
The problem is your first selection in the RTCC setup.
RTCC_EXT_H_TO_L
This says to clock the RTCC, from it's external clock input pin T0CKI (Timer 0 clock input). Unless you have a clock on this pin, the RTCC will never count....
Change this for 'RTCC_INTERNAL'.
KT315
PostPosted: Tue Oct 27, 2009 8:46 am     Reply with quote
oh, thanks for timers!
Now I've got another lil problem. I'm trying to reproduce keyboard&mouse2 example.
I've got a composite hid descriptor, its first report is used for emulating keyboard. (This descriptor works with other language usage.)
It is composed with modifiers byte and buttons byte. To emulate this kbd I need to send 3 bytes - report id, modifier and button code.
To send messages I use my own polling function. When I want to send a single character, I set kbdSend flag on and define kbdBuffer[1] and kbdBuffer[2], and then call the function.
unsigned int8 kbdBuffer[3] = {1, 0, 0};
unsigned int8 kbdSend=0;
void pollHid()
   if (!usb_enumerated()) return;
   if (kbdSend == 1)
      // keyboard array is already defined
      usb_put_packet(1,kbdBuffer,3,USB_DTS_TOGGLE);
      kbdSend = 15;
   else if (kbdSend == 15)
      kbdBuffer[1] = 0;
      kbdBuffer[2] = 0;
      kbdSend = 0;
There's current usage:
while (1)
      usb_task();
      kbdBuffer[0] = 1;
      kbdBuffer[1] = 0;
      kbdBuffer[2] = 4;
      kbdSend=1;
      pollHid();
      delay_ms(10);
      usb_task();
      pollHid();
      delay_ms(10);
      usb_task();
I think that this code sould send little 'a' character (code 4 in hid tables), send ternination nil and then wait for a second.
But I get repeating 'a' character. My program can't send data {1,0,0}??
PostPosted: Tue Oct 27, 2009 9:26 am     Reply with quote
To 'send' a single key, you need to do two things.
Send the three bytes you have already identified (saying that the key is pressed), and then send the 'key released' sequence.
You are sending the 'key pressed' sequence, but never sending the key released sequence, so you will see the character repeating at the programmed keyboard repeat rate.....
KT315
PostPosted: Tue Oct 27, 2009 9:31 am     Reply with quote
I'm calling pollHid, it sends defined key and sets kbdSend flag into 15. The next call of pollHid should send {1,0,0} and set kbdSend flag into 0.
