arunb
Unable to draw line on glcd (T6963 controller) |
Posted: Wed Oct 21, 2009 7:08 am |
PCH: 4.073
I am using a 18F4620 and a 240x128 graphical LCD (type: GDM240128B.....http://www.xmocular.com/upload_img/2007110153232813.pdf), this uses the T6963 toshiba controller.
LCD data port is at portB, the other control pins are connected to portA
I was able to implement Treitmey's driver for the T6963...see http://www.ccsinfo.com/forum/viewtopic.php?t=19957&highlight=graphical+lcd
I also implemented a glcd_pixel() function and was able to do the following
1. set a pixel at each corner of the screen..at (0,0), (239,0), (0,127) and (239,127) etc.
2. Print character at specific locations
3. The example code (drawing a black square) in the driver file also worked
I used the glcd_line() function in the graphic.c file shown below..
glcd_line(0,0,239,0,0,1);
this drew a line from o to around 20 pixels
glcd_line(0,0,153,0,0,1);
this drew a line from 0 to 103 pixels (ie: 103,0)
strangely the glcd_circle function works very well..also I could set each pixel after 103 to 239 by continously incrementing x position and then calling glcd_pixel()..
Please explain what's wrong...???
thanks
arunb |
treitmey
Posted: Wed Oct 21, 2009 8:27 am |
You say glcd_line function doesn't work.
But you don't show what that function is.
It is not in the link.
Will you show me that code? |
arunb
Posted: Wed Oct 21, 2009 11:14 am |
Actually now I am not in my workplace now. The glcd line function can be found in the graphics.c file in the picc/drivers folder.
If you still need that function I can post it tomorrow first thing in the morning.
Is the problem due to the fact that the lcd module is 240x125 and not 240x64?
arunb |
arunb
RE |
Posted: Thu Oct 22, 2009 4:27 am |
Ok here is the code for the glcd_pixel function...
void glcd_pixel(int16 x,int16 y,int1 color)
int8 r=0,c=0;
c=color;
r=fmod(x,8);
glcd_cmd16bits(0x24,GraphicsHome+(y*GraphicsArea+(x/8))); //set the location
glcd_cmd0(0xF0|(c<<3)|(7-r));
I am keeping MD2, CE and FS low.
I found that to draw a 239 pixel long line (horizontal) I need to draw a line from 0 to 127 and then from 127 to 239, ie : Line1= (0,0) to (127,0) and Line2= (127,0) to (239,0)..the code is given below
glcd_line(0,0,127,0,1); //Line 1
glcd_line(127,0,239,0,1); //Line2
Is the display divided into two screen s of 127 pixels ???
please explain....
thanks
arunb |
arunb
Solved...I found the problem |
Posted: Thu Oct 22, 2009 5:17 am |
Finally I found the problem, I had not defined LARGE_LCD in the graphics.c file.
Thank you treitmey for the help, the driver now works beautifully....
thanks
arunb |
