pic16f84 thermometer using DS18B20
gr1ph0n
PostPosted: Sat Oct 17, 2009 4:35 am     Reply with quote
Hello. I've built a digital thermometer with pic16f84 and DS18B20 from this site: http://www.coolcircuit.com/project/digitemp/ and it's not working very well. The sensor is showing about 72 degrees C in a room. In the original project the sensor is DS1820 but I only have DS18B20. Could someone help me modify the source codes thus showing the right temperature? I have no programming experience, that is why I am asking for your help.
The source codes:
main.c
#include <16F84A.h>
#fuses NOWDT,XT, NOPUT, NOPROTECT
#include <mylcd.c>
#include <ds1820.c>
// main program start here
   int buff[9], sensor, n,temp,temp_dec;
   delay_ms(50);
   lcd_init();
   while(true)
      sensor=0;
      init_ds1820(sensor);
      write_ds1820_one_byte(0xcc, sensor);  // skip ROM
      write_ds1820_one_byte(0x44, sensor);  // perform temperature conversion
      while (read_ds1820_one_byte(sensor)==0xff); // wait for conversion complete
      write_ds1820_one_byte(0xbe, sensor);  // read the result
      for (n=0; n<9; n++)     // read 9 bytes but, use only one byte
         buff[n]=read_ds1820_one_byte(sensor);  // read DS1820
      temp=buff[0]>>1;
      if ((buff[0] & 0x1)==1)
         temp_dec=5;
         temp_dec=0;
      lcd_putc("\f");
      printf(lcd_putc,"Temp   :");
      printf(lcd_putc," %u.%u'C",temp,temp_dec);
} //enf of main program
ds1820:
#BYTE TRISA=0x85
#BYTE PORTA=0x5
#BYTE STATUS=0x3
#define RP0  5
#define C 0
// The following are standard 1-Wire routines.
void make_ds1820_high_pin(int sensor)
   TRISA = 0xff;
void make_ds1820_low_pin(int sensor)
   PORTA = 0x00;
   TRISA = 0xff & (~(0x01 << sensor));
// delay routines
void delay_10us(int t)
#asm
            BCF STATUS, RP0
 DELAY_10US_X:
            CLRWDT
            NOP
            NOP
            NOP
            NOP
            NOP
            NOP
            DECFSZ t, F
            GOTO DELAY_10US_X
#endasm
void delay_ms(long t)   // delays t millisecs
   do
     delay_10us(100);
   } while(--t);
void init_ds1820(int sensor)
   make_ds1820_high_pin(sensor);
   make_ds1820_low_pin(sensor);
   delay_10us(50);
   delay_10us(50);
int read_ds1820_one_byte(int sensor)
   int n, i_byte, temp, mask;
   mask = 0xff & (~(0x01<<sensor));
   for (n=0; n<8; n++)
      PORTA=0x00;
      TRISA=mask;
      TRISA=0xff;
#asm
      CLRWDT
      NOP
      NOP
#endasm
      temp=PORTA;
      if (temp & ~mask)
        i_byte=(i_byte>>1) | 0x80;   // least sig bit first
        i_byte=i_byte >> 1;
      delay_10us(6);
   return(i_byte);
void write_ds1820_one_byte(int d, int sensor)
   int n, mask;
   for(n=0; n<8; n++)
      if (d&0x01)
         PORTA=0;
         TRISA=mask;      // momentary low
         TRISA=0xff;
         delay_10us(6);
          PORTA=0;
          TRISA=mask;
     delay_10us(6);
          TRISA=0xff;
      d=d>>1;
I don't know if this is necessary but I'll post it anyway.
lcd.c
struct lcd_pin_map {                 // This structure is overlayed
           BOOLEAN enable;           // on to an I/O port to gain
           BOOLEAN rs;               // access to the LCD pins.
           BOOLEAN rw;               // The bits are allocated from
           BOOLEAN unused;           // low order up.  ENABLE will
           int     data : 4;         // be pin B0.
        lcd;
#byte lcd = 6                  // on to port B (at address 6)
#define set_tris_lcd(x) set_tris_b(x)
#define lcd_type 1           // 1 lines
#define lcd_line_two 0x40    // LCD RAM address for the second line
BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 3),0xC,1,6};
                             // These bytes need to be sent to the LCD
                             // to start it up.
                             // The following are used for setting
                             // the I/O port direction register.
struct lcd_pin_map const LCD_WRITE = {0,0,0,0,0}; // For write mode all pins are out
struct lcd_pin_map const LCD_READ = {0,0,0,0,15}; // For read mode data pins are in
BYTE lcd_read_byte()
      BYTE low,high;
      set_tris_lcd(LCD_READ);
      lcd.rw = 1;
      delay_cycles(1);
      lcd.enable = 1;
      delay_cycles(1);
      high = lcd.data;
      lcd.enable = 0;
      delay_cycles(1);
      lcd.enable = 1;
      delay_us(1);
      low = lcd.data;
      lcd.enable = 0;
      set_tris_lcd(LCD_WRITE);
      return( (high<<4) | low);
void lcd_send_nibble( BYTE n )
      lcd.data = n;
      delay_cycles(1);
      lcd.enable = 1;
      delay_us(2);
      lcd.enable = 0;
void lcd_send_byte( BYTE address, BYTE n )
      lcd.rs = 0;
      while ( bit_test(lcd_read_byte(),7) ) ;
      lcd.rs = address;
      delay_cycles(1);
      lcd.rw = 0;
      delay_cycles(1);
      lcd.enable = 0;
      lcd_send_nibble(n >> 4);
      lcd_send_nibble(n & 0xf);
void lcd_init()
    BYTE i;
    lcd.rs = 0;
    lcd.rw = 0;
    lcd.enable = 0;
    delay_ms(15);
    for(i=1;i<=3;++i) {
       lcd_send_nibble(3);
       delay_ms(5);
    lcd_send_nibble(2);
    for(i=0;i<=3;++i)
       lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( BYTE x, BYTE y)
   BYTE address;
   if(y!=1)
     address=lcd_line_two;
     address=0;
   address+=x-1;
   lcd_send_byte(0,0x80|address);
void lcd_putc( char c)
   switch (c) {
     case '\f'   : lcd_send_byte(0,1);
                   delay_ms(2);
     case '\n'   : lcd_gotoxy(1,2);        break;
     case '\b'   : lcd_send_byte(0,0x10);  break;
     default     : lcd_send_byte(1,c);     break;
char lcd_getc( BYTE x, BYTE y)
   char value;
    lcd_gotoxy(x,y);
    while ( bit_test(lcd_read_byte(),7) ); // wait until busy flag is low
    lcd.rs=1;
    value = lcd_read_byte();
    lcd.rs=0;
    return(value);
gr1ph0n
PostPosted: Sun Oct 18, 2009 4:37 am     Reply with quote
Nobody can help me?
PostPosted: Sun Oct 18, 2009 3:05 pm     Reply with quote
What was the real temperature in your room during this test ?
(Measured by a thermometer, or by your estimate).
gr1ph0n
PostPosted: Tue Oct 20, 2009 10:09 am     Reply with quote
Sorry for not responding, for 2 days i had trouble with my internet connection. The real temperature was 24 degrees C. The sensor is responding, when I put it near a heat source the temperature start to grow.
Although I have no programming experience, by logic (I guess) and with examples from this site, I made a program, please don't laugh because I was desperate to made my thermometer work for my baby.
When I compile it I receive this error: "Out of ROM, A segment or the program is too large @PRINTF_L32D_74FPFPF.
And this is the program:
#include <16f84.h>
#include "1wire.c"
#include "mylcd.c"
float ds1820_read()
int8 busy=0, temp1, temp2;
signed int16 temp3;
float result;
onewire_reset();
onewire_write(0xCC);
onewire_write(0x44);
delay_ms(200);
while (busy == 0)
  busy = onewire_read();
onewire_reset();
onewire_write(0xBE);
temp1 = onewire_read();
temp2 = onewire_read();
temp3 = make16(temp2, temp1);
result = (float) temp3 / 16.0;  //0.1 deg C resolution
delay_ms(200);
return(result);
float temperature;
 delay_ms(50);
   lcd_init();
//for  10 bit resolution mod
onewire_write(0x4E);
onewire_write(125);
  onewire_write(-55); //this should be done for proper working of DS18B20
   onewire_write(127);
onewire_reset();
    onewire_write(0x48);
    delay_ms(15);
while (1)
  temperature = ds1820_read();
lcd_putc("\f");
printf(lcd_putc,"Temp:");
printf (lcd_putc," %3.1f\n\r",temperature);
Help me if you can, please!
PostPosted: Tue Oct 20, 2009 10:46 am     Reply with quote
Use the ds18B20 driver from the CCS code library forum:
http://www.ccsinfo.com/forum/viewtopic.php?t=28425
gr1ph0n
PostPosted: Tue Oct 20, 2009 10:51 am     Reply with quote
That is what I have used. One question. I saw that, when I used "%3.1f" the error apears, can you tell me why %3.1f was put there, please. Thank you.
PostPosted: Tue Oct 20, 2009 10:59 am     Reply with quote
The 16F84A only has 1K rom. Floating point code uses a large amount
of ROM space. There isn't enough ROM space to do your floating point
printf statement.
gr1ph0n
PostPosted: Tue Oct 20, 2009 11:02 am     Reply with quote
printf statement.
Can I do something? I don't want something fancy, just to show the temperature.
Sorry for my noob questions and for my ignorance.
PostPosted: Tue Oct 20, 2009 11:14 am     Reply with quote
Try displaying the result as a signed integer instead of a float.
Make the changes shown in bold below:
printf (lcd_putc," %d\n\r", (signed int)temperature);
gr1ph0n
PostPosted: Wed Oct 21, 2009 3:48 am     Reply with quote
It worked. Thank you very much!
This is the code that worked for me with PIC16F84:
#include <16f84.h>
#include "1wire.c"
#include "mylcd.c"
float ds1820_read()
signed int16 temp3;
float result;
onewire_reset();
delay_ms(200);
while (busy == 0)
onewire_reset();
delay_ms(200);
return(result);
float temperature;
 delay_ms(50);
   lcd_init();
onewire_write(125);
   onewire_write(127);
onewire_reset();
    delay_ms(15);
while (1)
lcd_putc("\f");
printf (lcd_putc," %d", (signed int) temperature);
I want to make a statement: This is not my code!
