Access General Purpose Registers
freddayz
PostPosted: Thu Oct 15, 2009 5:28 pm     Reply with quote
Is there a command that I can use to access the data in the general purpose registers of the PIC16F917.
PostPosted: Thu Oct 15, 2009 5:37 pm     Reply with quote
See this recent thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=40398
And here for more info:
http://www.ccsinfo.com/forum/viewtopic.php?t=36803&start=3
freddayz
PostPosted: Mon Oct 19, 2009 12:09 pm     Reply with quote
Thanks for your help...
I did the following:
// Memory type assignment
#byte DATA1 = 0xA0      // define DATA1's address be careful*
#bit m_VCC_5V0 = DATA1.0
#bit m_VCC_3V3 = DATA1.1
#bit m_VCC3V3_GOOD = DATA1.2
#bit m_VCC_2V5 = DATA1.3
#bit m_VCC2V5_GOOD = DATA1.4
#bit m_VCC_1V8 = DATA1.5
#bit m_VCC1V8_GOOD = DATA1.6
#bit m_VCC_1V0 = DATA1.7
Afterwards, I can access the data by simply reading DATA1 or each specific bit. This is very simple compared to other answers I receive which wanted me to create a structure.
PostPosted: Mon Oct 19, 2009 12:52 pm     Reply with quote
The same method has been suggested in the above quoted post.
