aruna1
16F877A pwm trouble |
Posted: Mon Oct 19, 2009 6:25 am |
hi,
I'm using 16F877A to generate 38kHz for IR transmitter using pwm channel. I have used a 10Mhz crystal. CCS C version is 4.084.
My problem is at 50% duty voltage at pwm pin is about 2.4v
and at 30% duty voltage still 2.4v. At 5% duty voltage is about 1.6v.
Why isn't voltage changing according to duty?
And another problem is if I generate 1khz signal, 50% duty value is 512
but if I use 38khz the 50% duty value is 132. How does this happen?
And how to interface ADC value directly to pwm duty in this manner?
(if I use 1KHz I can directly use ADC value as duty).
Here is my code:
INT count=0;
setup_adc_ports (NO_ANALOGS) ;
setup_adc (ADC_OFF) ;
setup_psp (PSP_DISABLED) ;
setup_spi (SPI_SS_DISABLED) ;
setup_timer_0 (RTCC_INTERNAL|RTCC_DIV_1) ;
setup_timer_1 (T1_DISABLED) ;
setup_timer_2 (T2_DIV_BY_1, 65, 1) ;
setup_ccp1 (CCP_PWM) ;
setup_ccp2 (CCP_PWM) ;
set_pwm1_duty (0) ;
set_pwm2_duty (0) ;
setup_comparator (NC_NC_NC_NC) ;
setup_vref (FALSE) ;
WHILE (1)
IF (input (PIN_B5)||input (PIN_A2))
output_high(PIN_B4);
set_pwm1_duty (132) ; // 50% duty
set_pwm2_duty (132) ;
ELSE
output_low(PIN_B4);
set_pwm1_duty (13) ; // 5% duty
set_pwm2_duty (13) ;
delay_us (600) ;
set_pwm1_duty (0) ;
set_pwm2_duty (0) ;
delay_us (600) ;
// TODO: USER CODE!!
Posted: Mon Oct 19, 2009 11:06 am |
Quote: | My problem is at 50% duty voltage at pwm pin is about 2.4v
Why isn't voltage changing according to duty? |
We are not mind readers. Tell us what external circuits are connected
to the PWM pin. Tell us the Vdd voltage of the PIC. Tell us how you
are measuring the PWM voltage. Is it the peak-to-peak voltage of the
PWM signal ? Are you using an oscilloscope to measure it ?
Again, give full details. Show us the setup_timer_2() statements for
the 1 KHz mode and the 38 KHz mode. Post the set_pwm1_duty()
statement for each mode. Post the PIC's oscillator frequency for
each mode. Post the variable declarations of the duty cycle variable
(if a variable is used). Always post full details if you want an answer. |
aruna1
Posted: Mon Oct 19, 2009 11:11 am |
PCM programmer wrote: | Quote: | My problem is at 50% duty voltage at pwm pin is about 2.4v
Well oscillator frequency is 10MHZ all the time.
No external circuits. I just connected digital multimeter to pwm pin and measured it.
Posted code above. I used wizard to s\configure settings (pwm frequency initial duty,etc). |
Posted: Mon Oct 19, 2009 11:15 am |
You didn't post most of what I requested.
The meter is averaging the PWM signal. I don't know what the bandwidth
of the meter is. I wouldn't consider the meter to be a reliable method of
measuring the duty cycle. You need an oscilloscope for that. |
aruna1
Posted: Mon Oct 19, 2009 11:18 am |
PCM programmer wrote: | You didn't post most of what I requested.
vdd is 5v
And I don't know how to get that timer 2 thing you requested?
Anyway since DMM average voltage it gives corrct value for 50% pwm -->2.4v
But what about 30% and 5% ? |
Posted: Mon Oct 19, 2009 11:24 am |
All you have to do is copy and paste the line for setup_timer_2() from
your programs for 1 KHz operation, and for 38 KHz operation, into a post.
I said, how do we know what the bandwidth is for your meter ?
How do we know that it has a linear transfer function for converting
fractional duty cycles of a rectangular waveform into a DC voltage ?
We don't know.
I've answered all that I can on this thread. Someone else can
perhaps provide some more help. |
aruna1
Posted: Mon Oct 19, 2009 11:28 am |
PCM programmer wrote: | All you have to do is copy and paste the line for setup_timer_2() from
We don't know.
this is for 38khz
this is for 1khz
setup_timer_2(T2_DIV_BY_16,155,1);
i dont have any info about multimeter.
i dont have it for 1khz,coz i actually didnt save main with ![Embarassed](images/smiles/icon_redface.gif) |
mkuang
Posted: Mon Oct 19, 2009 12:18 pm |
aruna1 wrote: |
this is for 38khz
this is for 1khz
Those are the correct setup for a 38Khz and 1Khz pwm at 10 MHz. From your duty cycle values it looks like you are using 10 bit pwm instead of 8. If you want to directly drive the pwm with your 10 bit A/D you have to scale your A/D reading something like this:
long a_to_d_reading;
long duty_cycle;
//for 38Khz pwm
duty_cycle = (long) (a_to_d_reading*4*65/1024.0);
//for 1Khz pwm
duty_cycle = (long) (a_to_d_reading*4*155/1024.0);
You are measuring something that is not 30% or 5% most likely because you are not meeting the criteria in your program for generating a 30% or 5% signal. You are not going to know until you actually test your circuit with a scope as PCM Programmer pointed out.
If possible you should post a complete test program with the fuses. Right now we don't know whether you are using an external crystal or internal oscillator, or whether you set it up correctly.
aruna1
Posted: Mon Oct 19, 2009 12:22 pm |
mkuang wrote: | aruna1 wrote: |
this is for 38khz
this is for 1khz
long duty_cycle;
//for 38Khz pwm
//for 1Khz pwm
If possible you should post a complete test program with the fuses. Right now we don't know whether you are using an external crystal or internal oscillator, or whether you set it up correctly. |
Well problem is I don't have a oscilloscope.
And I wonder why PIC can't give pwm as I told it to do? I mean shouldn't PIC do as I command it through code? |
bkamen
Posted: Mon Oct 19, 2009 4:59 pm |
aruna1 wrote: |
You really need a scope.
You have to keep in mind you're plugging a square wave into a meter that probably rolls off at 1000Hz at best.
your PIC is probably working fine. The way you're trying to measure the output is not fine. _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D |
