tacho of motor
eng/ IBRAHIM
tacho of motor
PostPosted: Sun Oct 18, 2009 9:03 am     Reply with quote
Hi all
Anyone knows why this code not works.
I use 16f877 to control of motor speed using feedback of tachometer signal.
#use delay(clock=4000000,restart_wdt)
#ROM 0x3ff = {0x3478}
#define Triac PIN_b1     // Triac
#define ZCD PIN_b0       // Zero Cross
#ZERO_RAM
int j=1; int phaseangle=123;   int tacho;
void init()
disable_interrupts(GLOBAL);
disable_interrupts(INT_EXT);
disable_interrupts(INT_TIMER0);
output_low(Triac);                //  triac low
delay_ms(10);
#INT_TIMER0
void tempo()
output_high(Triac);               // triac high
#INT_EXT
void externa()
set_timer0(phaseangle);
if (j==0)
j=1;
ext_int_edge(H_TO_L);
else if(j==1)
j=0;
ext_int_edge(L_TO_H);
long rise,fall,pulse_width;
#int_ccp2
void isr()
   rise = CCP_1;
   fall = CCP_2;
   pulse_width = fall - rise;     // CCP_1 is the time the pulse went high
//init();
enable_interrupts(INT_EXT);
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_64);
int32 freq;
   setup_ccp1(CCP_CAPTURE_RE);      // Configure CCP1 to capture rise
   setup_ccp2(CCP_CAPTURE_FE);      // Configure CCP2 to capture fall
   setup_timer_1(T1_INTERNAL);      // Start timer 1
   enable_interrupts(INT_CCP2);     // Setup interrupt on falling edge
   while(TRUE) {
freq=(1000000/pulse_width);
output_d(freq);
if(freq<0x59)
phaseangle++;
delay_ms(10);
if(freq>0x59)
phaseangle--;
delay_ms(10);
