So why bother with all these other input/output pins?
lecutus
PostPosted: Fri Oct 16, 2009 4:05 pm     Reply with quote
In my case I'm using rs232 for input/output. So why bother with all these other input/output pins?
Second question. The proper use of input_a or the strategy of port = input_a(). Why? This can be found in get_swi_status(), it's listed at the very bottom of this post.
I inherited this program, and I'm in the middle of a rewrite. I usually write at a higher level, not to say i'm a bad [spam] or anything, it's more like fourth gen languages like C++, C#, and Delphi. So this bit shifting thing is still a little new. I've received extremely helpful advice from this site.
Here we go again.
I am using PCWHD 4.079
The Preprocessor:
#include <18F258.h>
//#fuses HS,PROTECT,NOLVP,WDT32,nowdt// original
#fuses HS,PROTECT,NOLVP,nowdt,brownout,BORV42,noprotect
#use rs232(baud=115200, xmit=PIN_C6, rcv=PIN_C7,  stream=rs_str)  // Jumpers: 8 to 11, 7 to 12
#include <can-18xxx8.c>
#byte pir1=0x0F9E
#define TMR1iF  0X00
#rom int 0xf00000={0x00,0x00,0x00,0x00}
#define offset_id 0x00
#define offset_e  0x02// original
#define offset_t  0x03// original
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
#include <input.c>
//char* str1;
 //char str1[100];
 int1 tf_rs232=false,tf_data_ok=false,tf_send_can=false,tf_send_232=false,tf_lube_ovr=false;
 int8 swi_status=0,loop_cnt=0,conv_lok,req_gear;       //buffer counter
 int8 sel_gear,cur_gear,gear, fuel_psi,oil_psi,water,rm_volts,rm_hrs,alr_pump,fmi,spn_count=0,fmi_count=0,k_char,x=0;
 int buffer[8],rx_len,rxstat;
 int16 rpm,outspeed,inspeed,pressure_out,lube_psi,lube_temp,pressure_max,crpm,volts,injt_psi,spn,x_cnt;
 int32 rx_id,rx_ad,hrs;
 float bpm;
 //int16 rpm_rs=740,ov_press_rs=7500,pump_id=0,id_num; //original
 int16 rpm_rs=740,ov_press_rs=750,pump_id=0,id_num;
 int8 swi_rs=0,gear_rs=124,cnt_send_can=0,engine=0,trans=0;
PIC18F258 Pins used
PIN_C6 transmit via rs232/serial
Used by: Rs232()
PIN_C7 Receive via rs2232/serial
Used by: Rs232()
pin_b4
Set high & low
Digital I/O, interrupt-on-change pin
Used by: RS232()
pin_b5
Set high & low
Digital I/O, interrupt-on-change pin, Low-voltage ICSP programming enable
Used by: ck_rs232()
pin_c4
if (!input(pin_c4)) rx_id=300; //remote swi interface C4=0
if (input(pin_c4)) rx_id=301; //local switch interface C4=1
Digital I/O
Used by: send_swi_status()
The context/modules in which they're used
void RS232()
  //printf("inside  RS232()>>>>>>");line_feed();
  output_low(pin_b4);//for blinking light?
  printf("I%04lu",id_num);
  rpm=rpm>>3;                             //rpm
  printf("R%04lu",rpm);
  switch (cur_gear)                       //gear
    case (124) : gear = 1; printf("G0%u", gear); break;
    case (125) : gear = 2; printf("G0%u", gear); break;
    case (126) : gear = 3; printf("G0%u", gear); break;
    case (127) : gear = 4; printf("G0%u", gear); break;
    case (128) : gear = 5; printf("G0%u", gear); break;
    case (129) : gear = 6; printf("G0%u", gear); break;
    case (130) : gear = 7; printf("G0%u", gear); break;
    case (131) : gear = 8; printf("G0%u", gear); break;
    case (132) : gear = 9; printf("G0%u", gear); break;
    case (133) : gear = 10; printf("G%u", gear); break;
    default    : {}; break;
    //oil pressure
  printf("O%03u", oil_psi);
     //water temp
  printf("C%03u",water);
    //battery volts
  printf("V%02lu.%u", volts, rm_volts);
    //pump speed
  printf("W%04lu",outspeed);
    //fuel pressure
  printf("F%03u", fuel_psi);
    //convertor lock
  printf("L%u",conv_lok);
     //ov pressure set
  printf("S%05lu", pressure_max);
    //pump output pressure
  if (pressure_out>15000) pressure_out=15000;
  printf("P%05lu", pressure_out);
    //pump lube pressure
  printf("X%03lu", lube_psi);
    //pump lube temperature
  printf("Y%03lu", lube_temp);
     //barrels per min
  if (bpm<1) printf("B0%02.2f",bpm);
  if ((bpm>=1)&&(bpm<10)) printf("B0%2.2f",bpm);
  if (bpm>=10) printf("B%2.2f",bpm);
    //engine hrs
  printf("H%05lu", hrs);
  printf("E01T01");//this is how to dummy the info
    //diagnostics spn
  printf("D%04lu", spn);
    //diagnostics fmi
    //printf("Z%04lu",pump_id);
  printf("_%02u", fmi);
  printf("!\r\n"); //delimiter
  tf_send_232=false;
  output_high(pin_b4);
  //printf("LEAVING  RS232()<<<<<<<<<<");
  line_feed();
 void ck_rs232()
   int1 val;
   //int8 x, k;
   val = kbhit();
   // printf(">>>> ENTERING ck_rs232() kbhit = %u >>>>>>",  val  );   line_feed();
    if (kbhit() /*|| getc()== '!'*/ )
       k_char=getc();
       //printf("k_char=%c" , k_char); line_feed();
       if (k_char =='!' || k_char == 0x21) // ! = exclamation = 0x21
            tf_rs232=true;
            //printf("tf_RS232 = %u", tf_RS232,);line_feed();
            x=0; x_cnt=0;
            tf_data_ok=false;
            output_low(pin_b5);
       if ((k_char=='i') | (k_char=='I'))
         {get_setup();}
    if (tf_rs232)
         //get_info_rs232_2();
         get_info_rs232_3();
         tf_rs232=false;
         //tf_data_ok=true;
         output_high(pin_b5); // this maybe it!!!!!!!!!!!!! Nope leave alone
void send_swi_status()
     if (tf_send_can)       //if true send this data via
       buffer[0]=swi_rs;     //swi status packet
       buffer[1]=0x00;
       buffer[2]=*(&rpm_rs);
       buffer[3]=*(&rpm_rs+1);
       buffer[4]=*(&ov_press_rs);
       buffer[5]=*(&ov_press_rs+1);
       buffer[6]=gear_rs;
       buffer[7]=0xff;
    else                //else only send swi_status
       buffer[0]=swi_status;
       buffer[1]=0x00;
       buffer[2]=0xff;
       buffer[3]=0xff;
       buffer[4]=0xff;
       buffer[5]=0xff;
       buffer[6]=0xff;
       buffer[7]=0xff;
    if (tf_lube_ovr) buffer[1]=0x08; //bit4 buffer[1]=1 to override auto lube
    rx_id=rx_id<<8;
    can_putd(rx_id,&buffer[0],8,1,TRUE,FALSE);
    if (tf_send_can) cnt_send_can++;    //setup to send 232 data 3 times
    if (cnt_send_can==3) tf_send_can=false; //then revert to normal mode
void get_swi_status()
   int8 port;
   swi_status=0;                       //assume all switches off
   tf_lube_ovr=0;                      //assume lube override=false
   port=input_a();
   delay_ms(1);
   if (!bit_test(port,0)) swi_status=1; //throttle up
   if (!bit_test(port,1)) swi_status=2; //throttle down
   if (!bit_test(port,2)) swi_status=3; //shift up
   if (!bit_test(port,3)) swi_status=4; //shift down
   if (!bit_test(port,4)) swi_status=5; //max up
   if (!bit_test(port,5)) swi_status=6; //max down
   port=input_c();
   delay_ms(1);
   if (!bit_test(port,0)) swi_status=7; //start
   if (!bit_test(port,1)) swi_status=8; //stop
   if (!bit_test(port,2)) swi_status=9; //e-stop
   if (!bit_test(port,3)) swi_status=10;//neutral/idle
   if (!bit_test(port,5)) tf_lube_ovr=true; //lube override=true;
Thanks L.
