HOPE RF12B module?
HOPE RF12B module?
PostPosted: Sat Oct 17, 2009 2:32 pm     Reply with quote
Trying to use a HOPE RF12B module.
Is there some hints on setup the SPI communication?
bungee-
PostPosted: Sat Oct 17, 2009 4:25 pm     Reply with quote
Manufacturer: http://www.hoperf.com/rf_fsk/rfm12b.htm
I am struggling with this modules. Sadly I lost the good code due to HD crash. According to PDF from the manufacturer this should be good setup for SPI
setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_XMIT_L_TO_H|SPI_CLK_DIV_4);
I'm using 8MHz internal oscillator in that particular case.
Also I found a German forum with CCS code, but it didn't work for me.
Here is the forum link: http://www.mikrocontroller.net/topic/73658
PostPosted: Sun Oct 18, 2009 1:51 am     Reply with quote
I'm not using the HopeRF modules, but I can confirm, that SPI Mode 0, as sel in your use_spi() statement is correct according to the manufacturer datasheet. Also SPI speed should no problem, because the chip works up to 20 MHz. So either a hardware problem or incorrect SPI command format should be expected.
