The 18F26j11 is without EEPROM, not happy with it:-(
I use RS232 to send some setup to the system, 10 byte!
How to store my config data on the fly when there is no EEPROM?
Posted: Mon Oct 19, 2009 11:33 am
Add an external EEPROM chip. Use an eeprom driver from the CCS
drivers directory.
Posted: Mon Oct 19, 2009 12:10 pm
Yes it's a solution but I already use all the pin. Is it possible to use the internal ROM to store data?
bkamen
Posted: Mon Oct 19, 2009 12:16 pm
theoretically yes.
You would do a WRITE_PROGRAM_MEMORY to someplace.
The problem is: what is the block size and endurance of the FLASH. If you write seldom, then you're ok. If you write a lot, you could wreck the flash cells.
External EEPROMs are a different technology that allows for more write cycles. _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D
