How is the way to measure the time of each program cycle ?
Posted: Thu Oct 15, 2009 2:23 pm
To measure the time required for a block of code, you can use the
MPLAB Simulator's Stopwatch feature. This thread has instructions on
how to use it:
http://www.ccsinfo.com/forum/viewtopic.php?t=38351
You can also set an i/o pin high at the start of a routine and low at the
end, and use an oscilloscope or a logic analyzer to see the pulse length,
and thus find the length of the routine.
bkamen
Posted: Fri Oct 16, 2009 12:14 am
I do this a lot. _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D
