USB Data transfer
Neddie
USB Data transfer
PostPosted: Mon Oct 12, 2009 12:29 am     Reply with quote
Hi to all.
I'm not familiar with USB so please bear with me if I'm asking the obvious.
I'm using the CCS driver (CDC mode) to transfer data from a PC to a PIC18F2455. It seems I can't transfer more that 64 bytes at a time. I can transfer "packets" of 64 bytes one after another but not more than that at a time. Is it possible to transfer larger packets. If I wanted to transfer 10K of data I'd need to transfer 157*64 byte packets which is a bit of a pain.
RAM constraints in the PIC obviously limit the packet size , but I'd like to be able to do more than 64 bytes at a time.
Any tips helpful.
cheers
Rob
Rohit de Sa
PostPosted: Tue Oct 13, 2009 6:12 am     Reply with quote
The '2455 only supports low and full speed USB. The maximum packet size depends on the type of transfer taking place - that is, control, interrupt, isochronous, or bulk.
With full speed USB the maximum packet size that you can have is:
64 bytes for control,interrupt and bulk mode transfers; and,
1023 bytes for isochronous transfers.
High speed USB allows:
64 bytes for control and interrupt transfers;
1024 bytes for isochronous transfers; and,
512 bytes for bulk mode transfers.
http://www.beyondlogic.org/usbnutshell/usb4.htm
Rohit
Rohit de Sa
PostPosted: Tue Oct 13, 2009 6:14 am     Reply with quote
I forgot to add, USB-CDC is a bulk mode transfer.
Rohit
FvM
PostPosted: Tue Oct 13, 2009 8:28 am     Reply with quote
I don't exactly understand your problem with CDC packet size. Your sending data as a stream, the USB driver takes care of splitting your transmission request to multiple packets. What's the data source for your 10k?
