Frequency = Fosc / (4 * (period+1) *postscale)? (Power PWM).
Posted: Mon Oct 12, 2009 4:19 am
Frequency = Fosc / (4 * (period+1) *postscale) in PIC C Help. I don't understand if i want a channel PPWM works with frequency from 10kHz - 20kHz then period and postcale = ???.
bungee-
Posted: Mon Oct 12, 2009 6:22 am
uC with 8Mhz internal clock and 15kHz PWM would have setting: setup_timer_2(T2_DIV_BY_1,132,1);
Posted: Mon Oct 12, 2009 11:42 am
Here's an example of how to setup the Power PWM module in the 18F4431:
http://www.ccsinfo.com/forum/viewtopic.php?t=37206&start=2
By looking at the setup code, and the #use delay() frequency, and
the list of frequencies of the output signals, you should be able to
verify how the PWM frequency is calculated.
