Marq
Modifying kbd.c (from ccs) to use in PORT_D |
Posted: Sun Oct 11, 2009 4:00 am |
The below codes is taken directly from the ccs kbd.c, and i want to change it to apply in PORT_D(i am using PIC16F877A ). What
changes i should make to the code?
Furthermore, what are this value #byte kbd = 0xF81 and #byte kbd = 0xF83 is it the same for all PIC ?
Code: | // Un-comment the following define to use port B
// #define use_portb_kbd TRUE
// Make sure the port used has pull-up resistors (or the LCD) on
// the column pins
#if defined(__PCH__)
#if defined use_portb_kbd
#byte kbd = 0xF81 // This puts the entire structure
#else
#byte kbd = 0xF83 // This puts the entire structure
#else
#byte kbd = 6 // on to port B (at address 6)
#else
#byte kbd = 8 // on to port D (at address 8)
#endif |
Can someone clarify about it, thanks. |
Posted: Sun Oct 11, 2009 11:18 am |
Quote: | What changes i should make to the code? |
Don't make any changes. Read the comments in the code. They say
exactly what to do. They say to "un-comment" the #define statement
to make it work on Port B. So, to make it work on Port D, just leave
the #define statement "commented out" (as it currently is).
Don't make any changes to it.
Quote: |
Furthermore, what are this value #byte kbd = 0xF81 and #byte kbd = 0xF83 is it the same for all PIC ? |
The code is setup to automatically compile for the correct PIC type.
If you use a 16F PIC, the lower portion of the code code will be used.
Notice that it uses Port addresses of 6 and 8. Those are for 16F PICs.
You need to study #if, #else, and #endif statements and their purpose.
They allow "conditional" compilation of code, so that one program can
be compiled with different sections of code, depending upon your settings.
Read a book on this, or read an online tutorial. |
