xTeox
Problem with EEPROM read/write float custom routine |
Posted: Wed Oct 07, 2009 2:02 pm |
Hi, everyone!
I'm with a problem... my routine doesn't work. It is only writing the first byte (but it access 4 times the loop 'for') and I don't know why. And, when tries to read, it return 0.
The routines:
float EEPROM_ler (int e, int tamanho)
int i;
float dados;
dados = 0;
for (i = 0; i < tamanho; i++)
*((int*) &dados + i) = read_eeprom (e + i);
return dados;
void EEPROM_gravar (int e, int32 dados, int tamanho)
int i;
write_eeprom (e + i, *((int*) &dados + i));
I've tried to do the same with this alteration:
Code: | float EEPROM_ler (int e)
float dados;
int i;
int* ptr = &dados;
dados = 0;
for (i = 0; i < 4; i++)
*(ptr++) = read_eeprom (e++);
return dados;
void EEPROM_gravar (int e, int32 dados)
char i;
int* ptr = &dados;
write_eeprom (e++, *(ptr++));
But still the same!
PS.: it works with alterations to read/write long (int16). |
xTeox
Posted: Wed Oct 07, 2009 2:33 pm |
huahuahuahuahuahuahu........ forget it!.... I found the mistake!!!!!!!!!.... it's on the parameters of write function... I was sending a int32 data, when it must be a float data... uhahuahuauhhuahua....
ty who try to find a answer... |
