pic18f1330 oscillator
nicenoise
PostPosted: Tue Oct 06, 2009 7:00 am     Reply with quote
hello,
We are testing a design using pic18F1330 with 40mhz.
compiler v4.065
Anyone test this function?
With 20mhz and 15pf works fine,
but with 40mhz and 15pf works 1/2 speed that 20mhz...
Whats happened?
I'm using HS fuse,
how works H4 fuse? 10mhz clock with x4 acelerator, right?
Should be working with this method?
Thanks a lot for your help,
/a
PostPosted: Tue Oct 06, 2009 7:31 am     Reply with quote
40MHz, is not legal for the chip's oscillator. Read the data sheet...
Table 22-6 Fosc.
The chip supports:
40MHz _operation_ (not oscillation), with either:
10MHz crystal, and the PLL, or
40MHz _external oscillator_.
Yes. H4, with a 10MHz crystal, gives 40Mhz operation.
nicenoise
PostPosted: Tue Oct 06, 2009 8:10 am     Reply with quote
hello,
thanks.
Of course i'm using external oscillator at 40mhz... but not works. Its very slow...
Any special configuration? Fuses?
compiler version?
/a
