pyu
DS1307 problem. |
Posted: Mon Oct 05, 2009 1:41 pm |
Hi all.
I have a problem with my digital clock (pic16f887 and DS1307).
The schematic, DS1307:
pin 1: Crystal 32.768Khz
pin 2: Crystal 32.768Khz
pin 3: V + bat
pin 4: GND
pin 5: SDA (pic16f887 pin 23) and a pull-up resistor 4.7 K resistor to +5V
pin 6: SCL (pic16f887 pin 18) and a pull-up resistor 4.7 K to +5V
pin 7: NC
pin 8: +5V
Vbat is 2.8 - 3.0 V.
I use the following code (from this forum):
ds1307.c:
// ds1307.c -- Functions for the Dallas Semiconductor DS1307
// real time clock and NVRAM chip.
// The DS1307 uses BCD as its internal format, but we use it
// in binary format, outside of this module. So we have code
// to convert to/from BCD to binary in the functions below.
// Set the date and time.
The registers inside the ds1307 are in this format. The values are in BCD.
DS1307_SECONDS_REG 0
DS1307_MINUTES_REG 1
DS1307_HOURS_REG 2
DS1307_DAY_OF_WEEK_REG 3 // We don't use this register. Set it to 0.
DS1307_DATE_REG 4
DS1307_MONTH_REG 5
DS1307_YEAR_REG 6
#define DS1307_I2C_WRITE_ADDR 0xd0
#define DS1307_I2C_READ_ADDR 0xd1
// DS1307 register offsets
#define DS1307_SECONDS_REG 0
#define DS1307_MINUTES_REG 1
#define DS1307_HOURS_REG 2
#define DS1307_DAY_OF_WEEK_REG 3
#define DS1307_DATE_REG 4
#define DS1307_MONTH_REG 5
#define DS1307_YEAR_REG 6
#define DS1307_CONTROL_REG 7
#define DS1307_DATE_TIME_BYTE_COUNT 7 // Includes bytes 0-6
#define DS1307_NVRAM_START_ADDR 8
// We disable the SQWV output, because it uses
// a lot of battery current when it's enabled.
// Disable it by setting Out = Open Collector.
#define DS1307_CONTROL_REG_INIT_VALUE 0x80
char gca_ds1307_regs[DS1307_DATE_TIME_BYTE_COUNT];
void ds1307_set_date_time(void);
void ds1307_read_date_time(void);
char ds1307_read_byte(char addr);
char bcd2bin(char bcd_value);
char bin2bcd(char bin_value);
void ds1307_write_byte(char addr, char value);
char i;
// Convert the binary ds1307 data, which is passed in a global array,
// into bcd data. Store it in the same array.
for(i = 0; i < 7; i++)
gca_ds1307_regs[i] = bin2bcd(gca_ds1307_regs[i]);
// There are two control bits embedded in the following data.
// The Clock Halt bit is in bit 7 of the DS1307 Seconds register.
// We need to make sure that it's = 0, to make the clock run.
// The other bit is the 24/12 hour clock format bit, in bit 6 of
// the DS1307 Hours register. We need 24 hour mode, so set it = 0.
gca_ds1307_regs[DS1307_SECONDS_REG] &= 0x7f;
gca_ds1307_regs[DS1307_HOURS_REG] &= 0x3f;
// Now write the 7 bytes of BCD data to the ds1307,
// using inline code for speed.
disable_interrupts(GLOBAL);
i2c_start();
i2c_write(DS1307_I2C_WRITE_ADDR);
// Start reading at the Seconds register.
i2c_write(DS1307_SECONDS_REG);
// Write 7 bytes, to registers 0 to 6.
i2c_write(gca_ds1307_regs[i]);
// After setting the time in registers 0-6, also set the
// Control register. (index = 7)
// This just turns off the squarewave output pin.
// Doing it here, every time we set the clock registers,
// seems less risky than setting it near the
// start of the program, every time the unit powers-up.
i2c_write(DS1307_CONTROL_REG_INIT_VALUE);
i2c_stop();
// Read the date and time.
// The registers inside the ds1307 are in this order.
// The values inside the registers are in BCD.
// DS1307_SECONDS_REG_ADDR 0
// DS1307_MINUTES_REG_ADDR 1
// DS1307_HOURS_REG_ADDR 2
// DS1307_DAY_OF_WEEK_REG_ADDR 3
// DS1307_DATE_REG_ADDR 4
// DS1307_MONTH_REG_ADDR 5
// DS1307_YEAR_REG_ADDR 6
// We return the data in a global array. The data in is binary.
// seconds // 0-59 seconds
// minutes // 0-59 minutes
// hours // 0-23 hours
// day_of_week // 1-7
// date // 1-31 date
// month // 1-12 month
// year // 00-99 year (based on year 2000)
char i;
i2c_start();
i2c_start();
i2c_write(DS1307_I2C_READ_ADDR);
// Read the 7 bytes from the ds1307. Mask off the unused bits.
gca_ds1307_regs[DS1307_SECONDS_REG] = i2c_read() & 0x7f;
gca_ds1307_regs[DS1307_MINUTES_REG] = i2c_read() & 0x7f;
gca_ds1307_regs[DS1307_HOURS_REG] = i2c_read() & 0x3f;
gca_ds1307_regs[DS1307_DAY_OF_WEEK_REG] = i2c_read() & 0x07;
gca_ds1307_regs[DS1307_DATE_REG] = i2c_read() & 0x3f;
gca_ds1307_regs[DS1307_MONTH_REG] = i2c_read() & 0x1f;
gca_ds1307_regs[DS1307_YEAR_REG] = i2c_read(0);
i2c_stop();
// Now convert the data from BCD to binary.
// Do it after reading the bytes, so that
// the i2c reads can be done quickly.
gca_ds1307_regs[i] = bcd2bin(gca_ds1307_regs[i]);
// Read one byte at the specified address.
// This function is used to access the control byte
// or the NVRAM bytes.
char retval;
i2c_start();
i2c_write(addr);
i2c_start();
retval = i2c_read(0); // Don't ACK the last byte read
i2c_stop();
return(retval);
// Write one byte to the DS1307.
i2c_start();
i2c_write(addr);
i2c_write(value);
i2c_stop();
// This function converts an 8 bit binary value
// to an 8 bit BCD value.
// The input range must be from 0 to 99.
char bin2bcd(char binary_value)
char temp;
char retval;
temp = binary_value;
retval = 0;
// Get the tens digit by doing multiple subtraction
// of 10 from the binary value.
if(temp >= 10)
temp -= 10;
retval += 0x10;
else // Get the ones digit by adding the remainder.
retval += temp;
return(retval);
// This function converts an 8 bit BCD value to
// an 8 bit binary value.
// The input range must be from 00 to 99.
char temp;
temp = bcd_value;
// Shifting upper digit right by 1 is same as multiplying by 8.
temp >>= 1;
// Isolate the bits for the upper digit.
temp &= 0x78;
// Now return: (Tens * 8) + (Tens * 2) + Ones
return(temp + (temp >> 2) + (bcd_value & 0x0f));
And main.c:
#include <16F887.H>
#include <math.h>
#fuses HS,NOWDT,NOLVP,PUT,NOPROTECT,NOBROWNOUT,NOWRT
#use delay(clock = 20000000)
#define RTC_SDA PIN_C4
#define RTC_SCL PIN_C3
#use I2C(MULTI_MASTER,sda=RTC_SDA, scl=RTC_SCL)
#include "DS1307.c"
#include "Flex_LCD420.c"
char bin2bcd(char binary_value);
char sec;
char min;
char hrs;
char day;
char date;
char month;
char yr;
lcd_init();
printf(lcd_putc, "\f");
printf(lcd_putc, "\fTest program");
// Put some date and time values into the global date & time array.
gca_ds1307_regs[DS1307_SECONDS_REG] = 10; // 10 seconds
gca_ds1307_regs[DS1307_MINUTES_REG] = 10; // 10 minutes
gca_ds1307_regs[DS1307_HOURS_REG] = 8; // 8 AM
gca_ds1307_regs[DS1307_DAY_OF_WEEK_REG]= 0; // Skip this.
gca_ds1307_regs[DS1307_DATE_REG] = 4; // 4
gca_ds1307_regs[DS1307_MONTH_REG] = 9; // Sept
gca_ds1307_regs[DS1307_YEAR_REG] = 9; // 2009
// Write these values to the DS1307, for testing.
ds1307_set_date_time();
printf(lcd_putc, "\fAfter set time");
// Get these into variables with shorter names, so I can
// put them into printf more easily.
sec = gca_ds1307_regs[DS1307_SECONDS_REG];
min = gca_ds1307_regs[DS1307_MINUTES_REG];
hrs = gca_ds1307_regs[DS1307_HOURS_REG];
day = gca_ds1307_regs[DS1307_DAY_OF_WEEK_REG];
date = gca_ds1307_regs[DS1307_DATE_REG];
month = gca_ds1307_regs[DS1307_MONTH_REG];
yr = gca_ds1307_regs[DS1307_YEAR_REG];
printf(lcd_putc, "\f\%02d/\%02d/\%02d\r\n",day,month,yr);
printf(lcd_putc, "\%02d:\%02d:\%02d", hrs,min,sec);
And the result:
00/09/09
08:16:16
and is not ticking.
Can somebody please help me, is something wrong in my code?
Thanks. |
Posted: Mon Oct 05, 2009 1:51 pm |
Look at the code in the example here:
http://www.ccsinfo.com/forum/viewtopic.php?t=19926
You're missing the call to ds1307_read_date_time(). Add the line in
shown in bold below, to your program:
Quote: |
ds1307_read_date_time();
pyu
Posted: Mon Oct 05, 2009 2:25 pm |
Yes.
Thanks allot for your help, PCM Programmer
I found another small issue (reading day of week instead date)
Code: | printf(lcd_putc, "\f\%02d/\%02d/\%02d\n",date,month,yr);
printf(lcd_putc, "\%02d:\%02d:\%02d\n", hrs,min,sec);
printf(lcd_putc, "Day of week: \%02d", day); |
With this changes, my clock work fine ![Smile](images/smiles/icon_smile.gif) |
