Compilation error...
Sink0
PostPosted: Thu Oct 01, 2009 10:50 pm     Reply with quote
Hi I'm trying to compile the project from this site: http://www.semifluid.com/?p=23
line 156 and 168: Expression must evaluate a constant
line 204: 41 not defined correctly
The problem is at the header: usb_desc_hid 8-byte.h
Here is the code:
c:\program files\picc\drivers\usb_desc_hid.h
What is that error and how can I fix it?
Thanks!!
Code replaced by directory.
Reason: Forum rule #10
10. Don't post the CCS example code or drivers.
-- Forum Moderator
PostPosted: Fri Oct 02, 2009 1:14 pm     Reply with quote
I looked at his website, and he says this:
Please feel free to contact me if you have any problems.
You should email him.
Sink0
PostPosted: Sat Oct 03, 2009 12:59 am     Reply with quote
I did, but I had no reply. The problem is that there is an #if where he define if the hid polling time is gonna be 1ms or 10ms. If I just let it be fixed on 1ms it does work. But I want to know why that #if can't be used.
