The pic that I will be using is PIC16F877A. I want to use TX/RX pin and I2C pins for different operations. Can it be? Does it affect PIC performance?
TX/RX for computer communication.
I2C for DS1302(real time clock).
Posted: Thu Oct 08, 2009 1:22 pm
DS1302 uses 3-wire SPI. It doesn't use i2c. Read the data sheet.
Look at this CCS example file for the DS1302. It uses rs-232 to send
data to the PC.
