Simplex Serial (1 pin) using CCS #use rs232 stream?
maxrate
PostPosted: Sun Sep 27, 2009 6:05 pm     Reply with quote
Hello, I have a project where I need a couple of USARTs to simply send data from the PIC to a couple of computers (I only need to send, not receive). Is there a way to use the serial library #use rs232 with only a 'xmit' (no rcv) pin? I'm trying to save pins on the PIC as I need as many as the 18F4520 can offer me! thanks everyone.
PostPosted: Sun Sep 27, 2009 6:33 pm     Reply with quote
Yes, the compiler will create a software UART for this purpose, and use the pin specified. If you don't specify both a Tx and an RX pin, a software UART is created, but that doesn't seem to be a problem for you!
Chad
maxrate
PostPosted: Sun Sep 27, 2009 6:44 pm     Reply with quote
So, if I understand you correctly (and perhaps I'm being overly optimistic), if I don't specify a RX pin when defining a USART, the CCS library will create a simplex (not full duplex) port? I'll have to try that - never thought about trying that.
PostPosted: Sun Sep 27, 2009 9:14 pm     Reply with quote
I would suggest - unless you already committed your C6,C7 pins
AND need a duplex Uart - that you use the hardware UART first.
Be warned - the software RX & TX uarts can receive &&|| transmit trash
easily when interrupted by any other process.
The software UART is NOT a cure all for needing multiple RS_232 ports
as using INTS can and will wreck reliability of the data stream eventually.
ONLY the hardware implemented USART RX/TX is immune.
