certain && for sure disabling CAN bus 18f458
PostPosted: Sun Sep 27, 2009 2:42 pm     Reply with quote
OK - so i read the ccs header file for the 18f458 ( no can related entries)
and then the datasheet, which seems to say that the CAN module is not actually enabled at power on by default.
BUT darned if i can find any reference or discussion in the CCS doc on how to be dead sure that the CAN module is DISABLED 100% when using das compiler.
Having been solidly burned before by missing subtleties of PIC startup INIT coding, i'd be grateful for any comments that could point me toward a certainty of being able to init said chip but be positive that CAN was no way functional or being a pin vampire that i am not expecting.
tx
PostPosted: Sun Sep 27, 2009 3:09 pm     Reply with quote
The 18F458 data sheet shows that the OPMODE bits in the CANSTAT
register default to Configuration Mode. The block diagram for the i/o
pins appears to show that the CANTX signal is only enabled for output if
the OPMODE bits are in Normal Mode. Therefore, it appears that CANTX
is disabled upon power-on reset.
Compiling a short test program shows that the startup code does not
write to the CANCON register. Therefore, it appears that the CANTX
pin will remain disabled.
.... void main()
0004:  CLRF   TBLPTRU
0006:  BCF    RCON.IPEN
0008:  CLRF   FSR0H
000A:  CLRF   FSR0L
000C:  BSF    ADCON1.PCFG0
000E:  BSF    ADCON1.PCFG1
0010:  BSF    ADCON1.PCFG2
0012:  BCF    ADCON1.PCFG3
0014:  MOVLW  07
0016:  MOVWF  CMCON
.... while(1);
0018:  BRA    0018
Test program:
#include <18F458.h>
#fuses HS, PUT, BROWNOUT, NOWDT, NOLVP
