ccowley
10 bit hardware PWM on a 12F683 |
Posted: Thu Sep 17, 2009 4:45 pm |
I have read everything I can find on the 10 bit PWM, but I still don't seem to be able to get it working properly. Admittedly I am new to programming in C. I have always programmed PICS with Pic Basic Pro and my transition has been somewhat slow. Pic Basic Pro doesn't support 10 bit PWM and I need it for a smooth fade-up/fade-down of an LED, so I thought this would be a simple project.
Any help for this slow C learner would be greatly appreciated!!!
The code I have been messing with is below. At this point I have just been trying to get it to switch between different brightness levels, not even fade, but it is not working.
PCW Compiler V. 4.099
#include <12F683.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOMCLR //Master Clear pin used for I/O
setup_adc(ADC_CLOCK_DIV_2);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_1,0,1);
setup_ccp1(CCP_PWM);
set_pwm1_duty(0);
setup_comparator(NC_NC);
setup_vref(FALSE);
setup_oscillator(OSC_4MHZ);
// TODO: USER CODE!!
// int16 duty;
// duty=1000;
while (true)
set_pwm1_duty(1000L);
delay_ms (1000);
set_pwm1_duty(500L);
delay_ms (1000);
set_pwm1_duty (1L);
delay_ms (1000);
set_pwm1_duty (128L);
delay_ms (1000);
Posted: Thu Sep 17, 2009 5:08 pm |
Here's an example of 10-bit PWM mode. If you turn the trimpot, it
changes the PWM duty cycle.
Code: | #include <16F877.h>
#device adc=10
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
int16 value;
// Set the PWM frequency for 245 Hz (with a 4 MHz crystal)
setup_timer_2(T2_DIV_BY_16, 254, 1);
setup_port_a(AN0);
setup_adc(ADC_CLOCK_DIV_8); // Divisor for 4 MHz crystal
set_adc_channel(0);
delay_us(20);
value = read_adc(); // 10-bit ADC result
set_pwm1_duty(value);
ccowley
Thanks for trying to help! |
Posted: Thu Sep 17, 2009 8:36 pm |
I appreciate the effort at helping me out! As I mentioned, I have read everything I could find on it already, so I have already looked at that code. I guess what I am really asking is, "What is wrong with my code, that it doesn't work?" I must be doing something wrong, but I am not sure what it is. I am still in the process of getting a grip on the C language.
Do you see anything wrong my code? I will continue to tinker around and try to solve the problem. I just thought someone might be able to quickly see what my coding problem was so that I wouldn't have to continue spending so much time with the trial and error route.
Thanks again, I do appreciate the effort! |
Posted: Thu Sep 17, 2009 8:43 pm |
Most of the code in your program is unnecessary for PWM.
Look closely at the functions in my program, and compare the parameters
that I use to the ones that you use in the same functions. You will see
the problem. |
