Joan
Joined: 29 May 2004 Posts: 41 Location: Barcelona, Spain
read/write int32 on internal EEPROM |
Posted: Wed Sep 23, 2009 9:39 am |
Hi all,
i'm trying to store 32bit data on internal eeprom and after to recover it .
Functions I'm using.
Code: | CCS Compiler version: 4.023 |
For write:
Code: | void write_float_eeprom(int32 n, int32 data)
int i;
for (i = 0; i < 4; i++)
write_eeprom(i + n, *((int *)&data + i) ) ;
For read:
Code: | float read_float_eeprom(int32 int n)
int i;
int32 data;
*((int *)&data + i) = read_eeprom(i + n);
return(data);
Code: | void read_EEPROM_setup ()
write_float_eeprom (0x00000000, 0x1234567F);
printf ("\fData stored in EEPROM\r\n");
delay_ms (500);
printf ("Data EEPROM Read\r\n");
data_32bits = read_float_eeprom (0x00000000);
printf ("32bit data: 0x%8LX\r\n", data_32bits);
printf ("[0]: 0x%X\r\n", read_eeprom (0x00));
printf ("[1]: 0x%X\r\n", read_eeprom (0x01));;
printf ("[2]: 0x%X\r\n", read_eeprom (0x02));
printf ("[3]: 0x%X\r\n", read_eeprom (0x03));
delay_ms (5000);
Results:
Code: | Data stored in EEPROM
Data EEPROM Read
32bit data: 0x0000007F
[0]: 0x7F
[1]: 0x56
[2]: 0x34
[3]: 0x12 |
So this function:
Code: | data_32bits = read_float_eeprom (0x00000000); |
seems to not work. Anybody has this problem ?. I'd tested previous post but with no luck.
Regards,
Joan |
Posted: Wed Sep 23, 2009 11:24 am |
Quote: |
I'm trying to store 32bit data on internal eeprom and after to recover it. |
I assume this means you want to read and write an 'int32' to eeprom.
Read your code with a critical eye:
int i;
int32 data;
return(data);
1. What is wrong with the function parameters ?
What is your intention, and what do actually have in the code above ?
2. What is wrong with the return value data type ?
What data type do you intend to return, and what type have you
told the function to return ?
3. Also, just as a cosmetic issue, you want to read and write an 'int32'
to the eeprom. What is wrong with the names you have given to the
functions ? What should the names of the functions be, if you want to
give them accurate names ? |
