kazama
eb500 bluetooth module (Updated With USART Code...Need help) |
Posted: Thu Sep 03, 2009 4:00 pm |
hi guys, I'm currently making the bluetooth integration with my robot after finished my sensor problem. I'm using this bluetooth
http://www.a7eng.com/products/bluetooth/productpages/eb500-ser.htm.
Actually I don't have any experience on setting the bluetooth using pic16f877a. But I found a bluetooth driver that I think can be use in my project.
http://www.ccsinfo.com/forum/viewtopic.php?t=31248&highlight=bluetooth.
But I found out that the driver may be used for serial port bluetooth module. Is there any other drivers for this module? I already search at the another forum, but got no result.
Also I just want to know on how to write up a code for the pic to create a connection (handshake) between module and laptop. I heard that we can set it by only adjust the ic settings at the module or do some basic stamp which I don't know what software should I use to program the basic stamp. hopefully someone can give me some idea on how to do the connection between laptop and module.
kazama
Here my code |
Posted: Wed Sep 16, 2009 2:49 am |
#include <16f877a.h>
#fuses hs,nowdt,noprotect,nolvp
#use delay (clock=20000000)
#byte TXSTA=0x98
#byte RCSTA=0x18
#byte SPBRG=0x99
#byte TXREG=0x19
#byte RCREG=0x1A
#byte PIR1=0x0C
#bit TXEN=TXSTA.5
#bit BRGH=TXSTA.2
#bit SYNC=TXSTA.4
#bit CREN=RCSTA.4
#bit SPEN=RCSTA.7
#bit TXIF=PIR1.4
#bit RCIF=PIR1.5
#byte portc=7
unsigned char a;
void display(unsigned char c) // subrountine to display the text on the screen
while (TXIF == 0);
TXREG = c;
unsigned char receive(void) // subrountine to receive text from PC
while (RCIF == 0);
a = RCREG;
return a;
void init(void) // subroutine to initialize
SPBRG=0x81;
BRGH=1;
TXEN=1;
CREN=1;
SPEN=1;
SYNC=0;
set_tris_c(0x01000000);
init();
while(true) // wait for 'ok' to be entered
a = receive();
if (a == 'd')break;
display('H');
could someone check the code. i'm using eb500 bluetooth module driver and PIC16F877A. i can see the 'H' on the hyperterminal. help me please |
