pilar
Digital Signature |
Posted: Mon Sep 14, 2009 8:43 am |
Hi, I want to know if I can put a digital signature into the program memory of a pic, the signature would contain the author name of program or other data, this is possible? ![Question](images/smiles/icon_question.gif) |
asmboy
Posted: Mon Sep 14, 2009 11:50 am |
YES you can
the question becomes do you want to be able to REPORT that to the outside world , in the event you are protecting your code ?
a common way to do this is include a documented (or not) command in the program that executes:
printf(" (c)Joe C. Blow 2009 etc etc"); |
Posted: Mon Sep 14, 2009 12:02 pm |
Hi asmboy, in this case my code will not be protected, I just want to place the author's |
asmboy
Posted: Mon Sep 14, 2009 12:27 pm |
if not protected and not printed - and not otherwise referred to
the compiler might choose in some versions to omit it
so located early in your MAIN or other function
int i;
rom char myid[9] = "Joe.Blow"; // one extra char req for \0
i=*myid;
this approach insures that it will exist in ROM and is typically to be found near or at the end of the code space
NOTE: this example is for 18f6722
you should check the LST * hex file for YOUR compiler version and selected pic to make sure it is doing what you want |
Posted: Mon Sep 14, 2009 2:24 pm |
Thank you.. |
