SPI
VINE (Guest)
SPI
PostPosted: Tue Sep 15, 2009 3:26 pm     Reply with quote
I need help. How do I set a bit within a register?
Register 0x66, bit 0xD0, set to 1.
I'm using software SPI.
"SPI_XFER();" Using this function.
Thanks many.
PostPosted: Tue Sep 15, 2009 3:34 pm     Reply with quote
If you want help with the SPI interface of a particular chip,
then post the chip's manufacturer and part number.
Also, post your PIC.
Post your compiler version.
Wayne_
PostPosted: Wed Sep 16, 2009 2:09 am     Reply with quote
Generally you would read the register, make the change and then write it back.
As PCM Said, you need to give more info for the device as it may be a write only reg.
Also, Register 0x66, bit 0xD0, set to 1. 0xD0 = 0b11010000
That is 3 bits!
So
val = spi_xfer(0);  // you need to send reg number first but that depends on the device
val |= 0xD0;
spi_xfer(val); // you need to send reg number first but that depends on the device
If it is a write only reg then you would need to store the value locally in your code or read the info from other registers.
