Password protection
UDIPTA
Password protection
PostPosted: Thu Sep 03, 2009 12:38 am     Reply with quote
I am writing a program which needs to be password protected. I am
using pic16f876a mcu. Can you give some idea how I can enter a
password using a single switch and how the password can be checked?
I can use an lcd for display.
Please help
pau
PostPosted: Thu Sep 03, 2009 7:10 am     Reply with quote
With only a single switch you need to do a sequence. Once you power-up the pic, the program have to wait until the switch is turned on, then the password can be like this:
2 seconds on-1 second off-2 seconds on.
It needs to have a range, for instance +/- 0.3 seconds for each interval.
Hope it helps you.
SherpaDoug
PostPosted: Thu Sep 03, 2009 3:26 pm     Reply with quote
If you want to get real sophisticated you could use Morse code.
PostPosted: Thu Sep 03, 2009 3:35 pm     Reply with quote
SherpaDoug,
Simon
