tamagee
Included library errors |
Posted: Wed Sep 02, 2009 8:27 pm |
I'm including an included library and the compiler is returning errors:
#include <18f26j50.h>
#fuses HS, NOWDT, NOPROTECT
#use rs232(baud=9600, xmit=PIN_B2, rcv=PIN_B1, stream=COM_A)
#use delay(internal=8M)
#include "stdlib.h"
#include "sht51.c"
#include "stdio.h"
#include "input.c"
#include "time.h" |
Quote: |
** Error 28 "C:\Program Files\PICC\drivers\time.h" Line 97(1,2): Expecting an identifier
*** Error 48 "C:\Program Files\PICC\drivers\time.h" Line 140(9,16): Expecting a (
*** Error 43 "C:\Program Files\PICC\drivers\time.h" Line 140(14,15): Expecting a declaration
*** Error 81 "C:\Program Files\PICC\drivers\time.h" Line 140(19,20): Expecting a basic type
*** Error 48 "C:\Program Files\PICC\drivers\time.h" Line 151(16,23): Expecting a (
*** Error 43 "C:\Program Files\PICC\drivers\time.h" Line 151(27,28): Expecting a declaration
Help? |
Posted: Wed Sep 02, 2009 10:31 pm |
It's a bug in the 18f26j50.h file. CCS has added a typedef structure
to that file. They have named it 'time_t', but that name is already used
in time.h. That's the reason for the compiler error. The problem is the
name shown in bold below, in 18f26j50.h:
Quote: |
// RTC Functions: setup_rtc(), setup_rtc_alarm(), rtc_read(),
// rtc_write(), rtc_alarm_read(), rtc_alarm_write()
// Structure used in read and write functions (pass pointer):
typedef struct {
int8 tm_year;
int8 tm_yday; // Not used by built in functions
int8 tm_mday;
int8 tm_mon;
int8 tm_hour;
int8 tm_wday;
int8 tm_sec;
int8 tm_min;
int8 tm_isdst; // Not used by built in functions
} time_t;
This structure is used in their rtc functions.
You can fix it by editing the 18f26j50.h file. Change the name shown in
bold above to something else, such as:
This bug affects 29 header files in the J-series PICs. It's in vs. 4.098.
You should email CCS about this bug. |
