Kova
LCD 16x2 Powertip And IR code grabber |
Posted: Mon Aug 24, 2009 11:31 am |
Hi all,
I bought this LCD 16x2: PC1602AR-GSO-A
I read on the Powertip homepage that the display has the ST7066U controller (http://www.powertip.com.tw/products_1.php?area_id=1170985616&area_name=Character%20LCD%20Module).
This site http://www.sitronix.com.tw/sitronix/product.nsf/Doc/ST7066U says that: "The ST7066U has pin function compatibility with the HD44780, KS0066 and SED1278 that allows the user to easily replace it with an ST7066U"
So, I tested this display with a 18F4550 this is the code:
Code: | #include <18F4550.h>
#device adc=8
#use delay(clock=20000000,RESTART_WDT)
#fuses HS, BROWNOUT, BORV20, PUT, STVREN, NOLVP
#define LCD_ENABLE_PIN PIN_E0 ////
#define LCD_RS_PIN PIN_E1 ////
#define LCD_RW_PIN PIN_E2 ////
#define LCD_DATA4 PIN_D4 ////
#define LCD_DATA5 PIN_D5 ////
#define LCD_DATA6 PIN_D6 ////
#define LCD_DATA7 PIN_D7
#include "lcd.c"
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_ON);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
ext_int_edge(0,H_TO_L);
enable_interrupts(INT_EXT);
enable_interrupts(global);
lcd_init(); //Initialise LCD
delay_ms(10);
lcd_putc("\fHello World\n");
lcd_putc("Line Number 2");
Nothing happens
In Proteus with a LCD Hitachi the code works correctly
I have also tried with this code: http://www.ccsinfo.com/forum/viewtopic.php?t=21290
With:
E0 -->RS
E1 -->Enable
E2 -->RW
Nothing, in Proteus works, on my circuit nope :(
I checked the circuit 100 times, seems ok!
On the RS pin I read 5V like in Proteus
Somebody can help me?
Thanks a lot
Posted: Mon Aug 24, 2009 11:50 am |
You are enabling interrupts without any interrupt routines. This will
cause the program to crash.
Quote: | setup_wdt(WDT_ON); |
You are enabling the Watchdog Timer, but you don't have a restart_wdt()
line in your while() loop. This will cause the program to constantly reset.
Quote: | setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_wdt(WDT_ON);
enable_interrupts(global); |
You don't need this code. These modules are all disabled by default
upon power-on reset of the PIC. You don't need to do it again in code.
Delete all of the lines above. |
Kova
Posted: Mon Aug 24, 2009 12:03 pm |
PCM programmer wrote: | You don't need this code. These modules are all disabled by default
Sure sorry, I writed the old code in the new those lines are disabled.
This is the code that I have tested:
#device adc=8
#include "lcd.c"
/*setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_wdt(WDT_ON);
enable_interrupts(global);*/
delay_ms(10);
Thanks PCM  |
Posted: Mon Aug 24, 2009 12:07 pm |
Is it now working ?
If not, then post what lcd driver you are using. Is it the Flex driver from
the Code library forum ? Or is it the CCS lcd.c driver ?
What is your compiler version ? |
Kova
Posted: Wed Aug 26, 2009 3:17 am |
PCM programmer wrote: | Is it now working ?
Wow...now it works!
I don't not why but this LCD works only if the Vee pin is connected to Ground (without any trimmer/pot)..Bohh...
Now I have another little problem
I want to capture the signal from an IR Decoder (TMFS5000).
I searched on the forum and I have found many projects, but I want only to capture the "time of the code".
I'm explain with the code
#fuses NOWDT,HS, PUT, NOPROTECT, BROWNOUT, MCLR, NOLVP, NOCPD
#define LCD_ENABLE_PIN PIN_E1 //E0
#define LCD_RS_PIN PIN_E0 //E1
#include "lcd.c"
INT8 Counter=0;
INT16 time[32];
INT16 time2[32];
INT1 Received=0;
INT1 AltoBasso=0;
INT1 Falso=0;
INT1 Cicalino=0;
#int_EXT
void EXT_isr(void)
//It is necessary because when pic startup there is an interrupt
if (Falso==0)
set_timer1(0);
Falso=1;
return;
time[counter]=get_timer1();
set_timer1(0);
counter++;
//Switch from High and Low
if (AltoBasso==0)
ext_int_edge(0,L_TO_H);
AltoBasso=1;
else if (AltoBasso==1)
AltoBasso=0;
//Grab max 32 edge
if (counter==32)
Received=1;
disable_interrupts(INT_EXT);
#int_TIMER1
void TIMER1_isr(void)
counter=0;
void AzzeraCode(void)
int i=0;
for(i=0;i<32;i=i+1)
time[i]=0;
void write_long_to_eeprom(int8 addr, int16 data)
int8 i2;
for(i2 = 0; i2 < 2; i2++)
write_eeprom(addr + i2, *((int8*)&data + i2) ) ;
int16 read_long_from_eeprom(int8 addr)
int8 i2;
int16 data;
*((int8*)&data + i2) = read_eeprom(addr + i2);
return(data);
delay_ms(250);
lcd_putc("\fHello\n");
int ct=0;
int contatore=0;
if(Received==1)
counter = 0;
Received = 0;
if(cicalino==0)
for(ct=0;ct<32;ct=ct+1)
write_long_to_eeprom(ct*2, time[ct]);
lcd_putc("Write\n");
time2[ct] = read_long_from_eeprom(ct*2);
lcd_putc("\fRead\n");
cicalino=1;
else if (cicalino==1)
for(ct=1;ct<32;ct=ct+1)
if ( abs((time[ct]-time2[ct])) < 300) //Threshold
contatore = contatore +1;
if (contatore >28) //Good?
lcd_putc("\fCorrect\n");
lcd_putc("\fNot Correct\n");
contatore = 0;
AzzeraCode();
The problem is that when I grab a "same code" the time of each edge is always different!!!
P.S.
In the absence of IR light, the output of the decoder is normally high. |
Posted: Wed Aug 26, 2009 11:54 am |
Describe the incoming signal to the PIC. What is the frequency and
the duty cycle ? Or, if it's an irregular pulse stream, then what is the
minimum pulse width? Post a link to a document that shows a timing
diagram of the pulses, if possible. |
Kova
Posted: Wed Aug 26, 2009 12:03 pm |
PCM programmer wrote: | Describe the incoming signal to the PIC. What is the frequency and
It's an irregular pulse stream, because I want to grab only one button from a generic remote controller.
The user push a button on the remote, the MCU grabs the code (the time of each pulse), saves the timing and associates a task.
So when the user push another time the button, the MCU reads the timing code and it compares with the timing saved in memory and if it's correct starts the task.
I don't know in advice the protocol used by the user's remote controller.
Do you think that is it possible to do that?
Thanks PCM for the help |
Kova
Posted: Fri Aug 28, 2009 4:49 am |
Arghh Nothing
I have used another IR Detector (TSOP1138...active LOW)..But nothing!!
It doesn't work correctly :(...The code is no always recognized
I write another code but..nope :( not work
#device adc=8
#define LCD_ENABLE_PIN PIN_E1 //E0 ////
#define LCD_RS_PIN PIN_E0 //E1 ////
#include "lcd.c"
unsigned INT32 time[32] = {0};
unsigned INT32 time2[32] = {0};
INT1 falso=0;
INT1 cicalino=0;
unsigned int8 rx_state = 0;
unsigned int32 timer_at_start, timer_at_end, low_time, timer_at_mid, period;
int1 data_avail = FALSE, caught_rise = TRUE;
#int_TIMER1
void TIMER1_isr(void) {
#int_EXT
void ext_isr(void) {
if (caught_rise) { // this is a rising edge
time[rx_state] = get_timer1();
set_timer1(0);
caught_rise = FALSE;
rx_state++;
else { // this is a falling edge
set_timer1(0);
caught_rise = TRUE;
rx_state++;
if (rx_state == 32) {
delay_ms(250);
rx_state = 0;
data_avail = TRUE;
int i=0;
for(i=0;i<32;i=i+1)
time[i]=0;
void write_long_to_eeprom(int32 addr, unsigned int32 data)
int8 i2;
for(i2 = 0; i2 < 4; i2++)
int32 read_long_from_eeprom(int32 addr)
int8 i2;
unsigned int32 data;
return(data);
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_wdt(WDT_ON);
set_tris_e(0x00);
set_tris_c(0xff);
port_b_pullups(FALSE);
set_tris_b(0xff);
lcd_init();
delay_ms(250);
rx_state = 0;
int ct=0;
int contatore=0;
restart_wdt();
if (data_avail)
data_avail = FALSE;
if(cicalino==0)
write_long_to_eeprom(ct*4, time[ct]);
lcd_putc("Scritto\n");
time2[ct] = read_long_from_eeprom(ct*4);
lcd_putc("\fLetto\n");
cicalino=1;
if ( ((time[ct]-time2[ct]) < 150) || ((time2[ct]-time[ct]) < 150) )
if (contatore >30)
printf(lcd_putc,"\fCORRETTO = %u", contatore);
printf(lcd_putc,"\fNON CORRETTO = %u", contatore);
contatore = 0;
AzzeraCode();
rx_state = 0;
delay_ms(250);
lcd_putc("\fWaiting");
Posted: Fri Aug 28, 2009 3:55 pm |
Describe the timing of the incoming signal completely. |
