RS485 Transmitter sending extra data
arloedx
PostPosted: Wed Aug 26, 2009 10:30 am     Reply with quote
I am using the rs485.c library to send data. I have two PIC18f252 and two MAX485 chips. I can send data but additional data is being sent. For example if I send the character 'A', the characters 'AH' are sent. Does anyone have an Idea how to correct this? My code is below. Thanks in advance.
#include <18f252.h>
#use    delay(clock=10000000)
//#use rs232(baud=9600,xmit=PIN_C6, rcv=PIN_C7)
#define LCD_RS_PIN      PIN_B0
#define LCD_RW_PIN      PIN_B1
#define LCD_ENABLE_PIN  PIN_B2
#define LCD_DATA0       PIN_B4
#define LCD_DATA1       PIN_B5
#define LCD_DATA2       PIN_B6
#define LCD_DATA3       PIN_B7
#include <lcd2.h>
#define RS485_RX_BUFFER_SIZE 64
#define RS485_USE_EXT_INT FALSE
#define  RS485_ID           0x01
#define RS485_ENABLE_PIN      PIN_C5
#define RS485_TX_PIN       PIN_C6
#define RS485_RX_PIN       PIN_C7
#include <rs485.c>
#include <stdlib.h>
void LCD_CHECK();
void state(unsigned char s);
void frequency(unsigned char frc);
int RS485_DEST_ID;
void LCD_CHECK()
   lcd_gotoxy(1,1);
   printf(lcd_putc, "System Ready");
   printf(lcd_putc,"\f");
int8 size=1;
int i, max = 5 ;
int8 bufsend[5] = {'A','B','C','D','E'};
int *pointer;
   output_high(RS485_ENABLE_PIN);
      rs485_init();
   lcd_init();
   LCD_CHECK();
   while(true)
      RS485_DEST_ID = 0x09;
      for(i=0; i<3; i++)
         pointer = &bufsend[i];
               rs485_send_message(RS485_DEST_ID, size, pointer);
          printf(lcd_putc,"\fSent: %c", bufsend[i]);
          delay_ms(400);
      RS485_DEST_ID = 0x07;
      for(i=3; i<max; i++)
          delay_ms(400);
PostPosted: Wed Aug 26, 2009 11:47 am     Reply with quote
You shouldn't start a new thread on the same topic. You have an
existing thread here:
http://www.ccsinfo.com/forum/viewtopic.php?t=39964
You can "bump" that thread to the top of the list by adding a post to it.
Everyone will see it.
