7 segment driver chip
Markdem
PostPosted: Mon Aug 24, 2009 10:26 pm     Reply with quote
Hi All, Doing a project with a stack of 7 segments, I have decided to make my own driver chip, cheaper the buying the maxim parts.
Here is my code;
#include <18F4680.h>
#fuses EC_IO,NOWDT,NOPROTECT,NOLVP,NODEBUG,NOMCLR
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0xa0)
const char digit[10]={
//0   1     2     3     4     5     6     7     8     9
0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90
int display_string[10] = {0, 1, 2, 3, 4, 5, 6, 7, 8};      //this is the last 4 digets of both displays, leading zero is not used
int index = 1;
int out_port = 0b11111110;
#INT_SSP
void i2c_isr()
      int state, incoming, address;
      state = i2c_isr_state();
      if(state < 0x80)                           //Master is sending data
            incoming = i2c_read();
            if(state == 0)                        //First received byte is address
               address = incoming;
            if(state == 1)                        //Second received byte is data
               display_string[address] = incoming;
#int_rtcc
void clock_isr()
//      delay_ms(500);                              //test delay only
      output_b(0xFF);
      output_d(digit[display_string[index]]);
      output_b(out_port);
      delay_ms(1);
      if(index >= 8)
            index = 1;
            index++;
            rotate_left(&out_port,1);
      output_b(0xFF);
      output_d(0xFF);
      setup_counters(RTCC_INTERNAL, RTCC_DIV_16 | RTCC_8_BIT);
        enable_interrupts(INT_RTCC);
        enable_interrupts(INT_SSP);
            delay_us(1);
It works, at least in simulation, but I was just wondering if there is anything i could\should improve or change.
mark
